Page 1 of 4 1 2 3 4
Troubleshooting temp issue #1544141
12/05/13 09:09 PM
12/05/13 09:09 PM
Sacramento, CA
cal_gecko Offline OP
Sacramento, CA
mild 360 in my '71 Dart with a 26" radiator (with shroud and flex fan) is running hot... takes about 20 minutes of driving but it gets up to about 235 degrees (even when it's 35 degrees out).. I tried a new radiator cap - same problem...
What's the most effective way for me to troubleshoot to determine whether there's a blockage in the radiator or in the block - or if there's something else going on?
If it's the radiator, I'm just gonna buy one of the Champion aluminum units sold here by a member for less than $200 delivered.. I just want to make sure that's the issue before I drop another $200
Re: Troubleshooting temp issue [Re: cal_gecko] #1544142
12/05/13 09:19 PM
12/05/13 09:19 PM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
When your car gets to 235 does it boil over?
Buy the cap that was suggested to you about two weeks ago that tells you the temp. right on it to determine if it's a gauge issue.
Or at the very least when it's 235 can you with it running slowly open the cap to see what's going on in there and/or use a meat type thermometer.
Ron
Re: Troubleshooting temp issue [Re: cal_gecko] #1544143
12/05/13 09:23 PM
12/05/13 09:23 PM
I'm assuming the timing is in the ballpark & the mixture is also (no vac leak). Is that stoplight to stoplight driving? If you take it out on the highway what does the temp do? I'd maybe shoot it with an IR gun to confirm what the temp actually is & my first step would be to toss the stat for a day which wont hurt things. What's the history of the radiator? You mentioned the cap, is it loosing coolant?
Re: Troubleshooting temp issue [Re: RapidRobert] #1544144
12/05/13 10:21 PM
12/05/13 10:21 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
If you just want to make some random guess. I'd start with the radiator. They age and clog up with build up.
Not often is there problems with the block.
Does it get hot while idling or how about coasting down a hill in neutral, will it pull the temp down?
Re: Troubleshooting temp issue [Re: cal_gecko] #1544145
12/05/13 10:35 PM
12/05/13 10:35 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Please don't buy a new radiator yet.
First get rid of the flex fan, it won't work and it won't last.
IMO Run a real mopar fan, I use the "216" fan, but there is another MP fan sold that works way better than any flex fan.
Please start there.
Re: Troubleshooting temp issue [Re: Challenger 1] #1544146
12/05/13 10:45 PM
12/05/13 10:45 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Check the initial and total timing and repor back! Is the vacu advance connected?
Re: Troubleshooting temp issue [Re: cal_gecko] #1544147
12/05/13 11:00 PM
12/05/13 11:00 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'Hot while idling'??? First...
What do you know about the condition of that block???
Coolant passages clear???
Have a rad shop check-out yer rad if in doubt...
OEM rad works just fine, and is my first choice...
Get rid of the flex-find a 7-blade A/C fan...
Re: Troubleshooting temp issue [Re: RSNOMO] #1544148
12/06/13 01:54 AM
12/06/13 01:54 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
This issue of Hotrod has an article titled "We tackle every cooling system problem known to man"
It is very informative!
http://www.ebay.com/itm/Hot-Rod-January-2014-/181256665246?pt=Magazines&hash=item2a33bd389e
Re: Troubleshooting temp issue [Re: RJS] #1544149
12/06/13 02:42 AM
12/06/13 02:42 AM
Sacramento, CA
Sacramento, CA
Ron
I had that cap on it tonight... it also showed 230
Re: Troubleshooting temp issue [Re: Challenger 1] #1544150
12/06/13 02:46 AM
12/06/13 02:46 AM
Sacramento, CA
Sacramento, CA
sorry guys.. I misreported on the type of fan... it's an OEM fan .. and it's in the shroud, so it should be pulling plenty of air through.
Timing is set and no vacuum leaks.. I resolved those issues last year when I was trying to get it running right
Re: Troubleshooting temp issue [Re: cal_gecko] #1544151
12/06/13 11:53 AM
12/06/13 11:53 AM
Cincinnati, Ohio
Cincinnati, Ohio
Then it's lean, most old motors are today because of the ethanol gas. Jet it up, I bet you it will help.
You sure the timing is correct?
Re: Troubleshooting temp issue [Re: cal_gecko] #1544152
12/06/13 05:00 PM
12/06/13 05:00 PM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
Ron
OK good so we know it's a real # then.
Does it get to that # just with time or time and cruising?
What I'm getting at is it a stuck in traffic (low airflow) problem or cruising problem too?
Top and bottom of radiator same temp?
Pull thermostat to see what temp. it is and or replace with 180 or 160.
Could belt be loose and slipping?
Lastly is there a spring in lower hose?
Ron
Re: Troubleshooting temp issue [Re: RJS] #1544153
12/06/13 05:35 PM
12/06/13 05:35 PM
P
Paul_Fancsali Offline
P
Some suggestions Make sure you are running a 8 blade water pump and no more then 35-40% antifreeze. Get a Mopar rad if possible they are expensive but worth it. Be sure there is no exhaust restictions IE Mice nests etc from all the sitting Also the thermostat I pulled a broken one out of a car last week first one in decades If you are using aftermarket AFB design it is too lean, do yourself a favor and get a older Carter AVS or a Holley
Re: Troubleshooting temp issue [Re: Challenger 1] #1544154
12/06/13 07:23 PM
12/06/13 07:23 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Everyones timing is set the question is where is it set
Re: Troubleshooting temp issue [Re: cal_gecko] #1544155
12/06/13 07:26 PM
12/06/13 07:26 PM
Maryville tn
67coronetman Offline
Maryville tn
I would use a clutch fan just saying it helped me i had a flex fan & it never did the job..
Old car are me......
Re: Troubleshooting temp issue [Re: 67coronetman] #1544156
12/06/13 07:32 PM
12/06/13 07:32 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Check the thermostate.. Ive seen new 1s that were bad.. Yours may not be opening up all the way..
I am truckless..
Re: Troubleshooting temp issue [Re: 340SHORTY] #1544157
12/06/13 07:34 PM
12/06/13 07:34 PM
Maryville tn
Maryville tn
Yes good point i agree.. good to check that too.
Re: Troubleshooting temp issue [Re: 67coronetman] #1544158
12/06/13 11:29 PM
12/06/13 11:29 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
what temp t-stat?
Got access to a thermal heat gun?
How hot is the bottom tank compared the the top? Are the cores of the radiator hot all the way across?
Does the temp go down if you turn the interior heat on high? (heater core is just a small radiator).
When at 230 does the air the fan is pulling while the engine running feel hot?
I feel that even if your timing was off, that at 35-45 degrees ambient there should be enough heat exchange for it to run normal "IF" the radiator is flowing.
What's the condition of the coolant?
Has it ever been brown/rusty?
Not sure how it is up there, but finding a radiator shop is near to impossible anymore.
Re: Troubleshooting temp issue [Re: cal_gecko] #1544159
12/07/13 01:04 AM
12/07/13 01:04 AM
Sacramento, CA
Sacramento, CA
OK... so I know that reading spark plugs can help see how the engine is running.. so I took a few photos of one of the plugs today.. this is after driving it home from work last night, and no running today.
Re: Troubleshooting temp issue [Re: cal_gecko] #1544160
12/07/13 01:04 AM
12/07/13 01:04 AM
Sacramento, CA
Sacramento, CA
2
Page 1 of 4 1 2 3 4
