Page 3 of 6 1 2 3 4 5 6
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME #15423
05/26/05 10:24 AM
05/26/05 10:24 AM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
Place a volt meter across your Alt, disconnect the battery and see for yourself what the voltage jumps to. Often times it will exceed 400 volts. In automotive electrical school (MOPAR) This was the first thing taught to us dealer weanies. DO NOT UNHOOK A BATTERY WHILE THE ENGINE IS RUNNING! I'm glad to hear you have never had a problem. A better way to see if the Alt is working would be to place a screw driver against the rear center, if it sticks the unit is at least somewhat working.
There ya go, its the FIRST THING a technician should know!!
the screwdriver on the rear bearing is a good way to tell if your regulator is working, because it picks up the magnetic field from the rotor. If the field is energized it will be magnet. The alternator may still not work though, especially if some back yarder was previously diagnosing it by disconnecting the battery. Bye bye rectifier! This can be confirmed by performing a ripple pattern test on the diodes.
sincerly, THE PROFESSOR
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 5537SG] #15424
05/26/05 10:34 AM
05/26/05 10:34 AM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
oh and another thing concerning the open circuit voltage....
remember those underhood welder kits you can buy??? You can still find them sometimes in the back of 4 wheeler magazines, or probably even JC Whitney
All they consist of is a Chrysler 100 amp alternator, and a solenoid that disconnects the battery then uses the alternator's high voltage to burn the electrode! It burns it at alot higher voltage than 18V!!! You regulate the power by regulating the rpm of the engine. Thats all they are.
They used the Chryco ones because they were the only alternators that would survive in that application.
You can weld with your own alternator on your own car if you want. Go outside, and disconnect the alternator while the field is energized, then hook up a stinger to your alternators output terminal. you can now burn rod all day or until your alterenator dies. (it wont be long) unless you have an old Chyrco 100 amper. They were overkill!
Sincerley Darrel Waltrip, oops, I mean the PROFESSOR!
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 5537SG] #15425
05/26/05 11:20 AM
05/26/05 11:20 AM
the boonies
aarcuda Online content
aarcuda  Online Content
the boonies
ARRRGGG! What you keep ignoring is that you are NOT DISCONNECTING the alternator field by disconnecting the battery!!! all youre doing is disconnecting the BATTERY. The field wires are still hooked up to the regulator.
the alternator PRODUCES voltage. The coil is a transformer that takes voltage and converts it. Disconnecting the battery should have absolutely no effect on the field wires on the alternator.
Im still gonna try it. heck, ive done it plenty of times before (just like stumpy says he has) and I never saw anything fry. So, now I'll put a voltmeter on my alternator and disconnect the battery. Im not afraid. I dont drive my truck until it snows anyways.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: aarcuda] #15426
05/26/05 11:40 AM
05/26/05 11:40 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
What truck? Year and brand? I've done it before and my dad before me. The regulator controls the generator or altenator, and nobody I know have ever had a problem. We use to do it all the time to get another car started. Drive one car there, leave it running, take the battery out and put it in the second car, and drive them both home. When in high school we didn't always have jumper cables and didn't always have room to push start.[altho I don't remember why not], but we did have tools most of the time. None of us ever had problems on any of the cars for the many years we owned them.
And sometimes the engine wouldn't run unless the batt cables were held together and tied for the trip back.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: amxautox] #15427
05/26/05 11:47 AM
05/26/05 11:47 AM
the boonies
the boonies
its a 79 plymouth trailduster. a classic convertable (if youre strong enough)
its got the same electronics as any 70's mopar plus more smog stuff (buts thats all disconnected now)
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: aarcuda] #15428
05/26/05 11:50 AM
05/26/05 11:50 AM
amxautox Offline
amxautox  Offline
Mine's a '76 Ramcharger. Sits a lot too. I use it mostly for dragging the bassboat up and down a couple dirt and gravel launches. And used it for dragging the trees out of the back 2 and the steep side hill when I opened it up for more pasture for the horse. It's road worthy again now. Still drives great on the original engine.
Tell me about that steel top, took it off a few times by myself on my back! Had a setup of 2x4s to get it done.
Tom
author unknown
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: amxautox] #15429
05/26/05 11:59 AM
05/26/05 11:59 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There is no way in Hades a car alternator will put out 400v it's physically impossible. As for spikes every time you turn on the headlights, the heater, the wipers, or the radio you cause a momentary spike and nothing blows. That is one of the reasons the main feed is a fusible link because it will outlast these spikes where a fuse won't. The welders are putting out high amperage and that is what welds not voltage. Put the books down and grab a wrench and get real world experience.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: aarcuda] #15430
05/26/05 12:34 PM
05/26/05 12:34 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
Im not ignoring anything. The whole part of it IS TO LEAVE THE FIELD ENERGIZED while the battery is disconnected! Then you have a transformer. By disconnecting the battery with the car running, the alternator still has the field energized!! Thus generates voltage that has nowhere to go!!!!! What do we know about electricity?? It takes the easiest way out!! Usually across a semi conductor of some type. The voltage will rise and rise, until it finds an escape.
If you disconnect the battery, the rest of electricaal system is subjected to this high voltage. If you just disconnect the alternator output terminal, you just subject the alternator to this high voltage.
Where do you think the power generated by the alternator goes when the field is still energized and the battery is disconnected??????????????
I'll give you a hint, you can use it to weld with!
I cant believe you guys think this is ok. A little knowledge is totally dangerous!!
just cause you got away with it before doesnt make it ok. Like I said earlier, the damage may not be immediately apparent!!
You guys really need to be educated properly in auto repair. Phone any local alternator rebuild shop and tell them the alternator you bought from them doesnt work because you disconnected the battery and the car stalled. Dont phone auto zone or whomever , phone a real rebuilder with electrical knowledge!
This is what separates real technicians from back yarders. A real tech knows the facts. I suggest you folks educate yourselves on this. This is why auto makers made it more difficult for back yarders that know eveything to work on thier products.Too many people with too little knowledge!
If you go try this on your Ramcharger, I hope you have a nice expensive stereo in there, and make sure you rev it up good and hard!
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: stumpy] #15431
05/26/05 12:45 PM
05/26/05 12:45 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
put down the greasy monkey wrench and educate yourself on laws of electricity. An alternator is very capable of producing 400V. You just dont know how an alternator works, and its quite obvious.
If its high amperage that welds, why arent your battery posts welding themselves together right now???? Theres plenty of amperage, and low voltage for you!! The voltage starts the spark, and the amperage keeps it going. Without the high voltage, theres no spark. Learn how welders work!
A fusible link and fuse will resist a SPIKE, not a SURGE. A fuse works off amperage not voltage!! How many fusible links in a new Ram?? theyre all Maxi fuses!
Go drag your feet across a carpet and get a static shock, WHy does the spark jump across 1/4 gap??? Theres very very little amperage, but high voltage, because it gets stored in the person dragging their feet.
Get with it!! your totally wrong.
Go change a leaf spring, thats more up your alley!
or help yourself out, and read a book, then go apply it in the field. I been there, and do that!!
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 5537SG] #15432
05/26/05 12:46 PM
05/26/05 12:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
My friend I have been a dealer mechanic since 1961 so I think I do have a small bit of on the job experience. What do you do for a living? The voltage regulator maintains the steady output. It will only allow what is needed to go to the system. Removing the battery does not disable the regulator. The reason you can weld with the AMPERAGE produced is that the draw causes the regulator the allow current to flow as drawn on up to the max amperage of the alternator. Every thing you have brought up requires the regulator the be stuck wide open and that doesn't happen when you pull the battery cable. What happens is exactly the oppisite the regulator senses the lower draw and lowers the output to match. If a board fails 5 months or 5 years down the road there is no way you can prove cause and effect. BTW if voltage welds why aren't your battery cables being welded now. The reason is that there isn't a high amp draw at the battery. When you weld you are creating an intentional direct short in the system which causes the regulator to sense a draw and signal for full output. Amperage causes heat bnot voltage. If voltage caused heat every wire with power through it would be hot and lo and behold they're not. Spend some more time reading you'll get it right eventually. You are going off the deep end on this with absolutely no proof.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: stumpy] #15433
05/26/05 01:40 PM
05/26/05 01:40 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
I'm a professional auto mechanic since 1988 I graduated with a 4.0 gpa and achieved 93% on the Ontario trade exam after completing the required time in school and a 9000 hour apprenticeship program. I have taken all the ASE tests and received master tech status, but since ASE isnt worth anything here, its just a way to waste money on credentials that arent recognized here
The voltage regulator turns the field off and on to reach a happy medium in the electrical system. It detects this by monitoring the system voltage via the sense terminal.
Nobody said it disables the regulator. The regulator sees the battery voltage as low and keeps the field energized. Just like the battery was low, it keeps the field energized because its trying to reach its set point of approximately 13.5-14.2 volts
I cant begin with whats wrong with this statement. First of all the regulator is just a switch with a zener diode in it. It senses the voltage and either turns the alternator field on or off. Its not magic. The alternators ability to supply enough amperage to weld with comes from the size of its windings and ability to dissipate heat. These traits made the Chryco 100amp a good choice
What voltage does the regulator see when the battery is not hooked up?? Disconnect your battery and check to see if the field stays energized. It will
Regulators dont sense draw, they sense voltage. and they tell the alternator what to do, turn on or off. When the voltage reaches the setpoint determined by the zener diode, it shuts off the alternator field.
Because like I said earlier, voltage creates the spark, not amperage, and batteries are only 12V, but they are capable of over 800 amps!! thats why they arent welding together right now. How is it your ignition coil can jump the spark plug gap and your battery cant??
Put your greasy cresent wrench across the battery terminals and see how low the amp draw is!!
Also spike and surge are interchangeable terms.
A spike refers to a voltage spike ( i.e sudden rise) in voltage! a surge is referred to as a sudden rise in current flow(i.e. the stuff that causes blackouts when everyone has their air conditioners on. )
The scary part is I've got this right, and I havent been doing it 45 years. This is basic auto repair knowlege. I dont know what credentials you have, but getting credit with snap on doesnt make you a technician.
The proof is out there. Ever change an ECM ?? Why does it come in an anti-static bag?? Why should you ground yourself before touching one? Why do the electronics workers wear anti static suits??? Its because of static shocks!! static shocks dont carry amperage, but they are capable of high voltage! just like your alternator. These people know the failures may or may not be immediate, but are aware of the dangers if they are.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 5537SG] #15434
05/26/05 01:48 PM
05/26/05 01:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There you go again. We are talking about old cars not new computer cars. Make up your mind. And my credenals consist of a Chrysler master mecahnics certificate that I earned before you were old enough to go to school. And it is recognized here. The end!
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: stumpy] #15435
05/26/05 01:57 PM
05/26/05 01:57 PM
the boonies
the boonies
I welded a screwdriver between the + side of a battery and the fender when I shorted it out once by accident. but thats neither here nor there.
lik stumpy said and as I have been saying, the voltage regulator (and hence the alternator field) is not disconnected when the battery is removed- so no jump in voltage.
the most I'll give you is that there is an overshoot of voltage when the battery is unplugged and replugged. voltage of maybe a few volts. But no way do I see damage occurring.
what about using jumper cables??? here you attach a battery to a car with a dead battery (dead battery with no voltage is close to no battery at all) and then DISCONNECT it after it starts. so people should be blowing all there electronics using jumper cables. thanks but no thanks.
same with using a big battery charger to start a dead car. Did it lots of times, never any damage. never say 400v either- ever- unless the car hit a power line.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: stumpy] #15436
05/26/05 02:07 PM
05/26/05 02:07 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
Here I am again, tell me whats different about a new car and an old car??? tell me! Id like to know! Is there a magical mystery date somewhere?
youre talking electrical, and Im talking electronic! they merged around the time of "transistorized ignition, and electronic voltaage regulators, and the transistor radio" These are all after you got your master chryco tech status!
an IC (integrated circuit) is an IC !!! which if you read back to my first post on this, youll see that I mentioned any IC was at risk by using these dinosaur methods of diagnostics.
maybe you should renew your credentials, they seem expired to me. afterall, thats before calculators had been invented, and man landed on the moon. So much more has since been learned! I encourage you to explore it.
and the facts are whats recognized here!
have a great day!
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 5537SG] #15437
05/26/05 02:19 PM
05/26/05 02:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No, actually correct facts are what is accepted and so far you have spouted all kinds of FACTS but you still haven't proven your point, cause and affect. There is a very large difference between the new ICs and the original electronics. The early stuff was a lot sturdier and less affected by surges or spikes, or that ever you want to call it,than the stuff they use today mainly because it was simple. If it wasn't for dinosaur methods of testing your parents would have been walking every where they went because us dinosaurs did quite well with or testing methods long before you learned your way and long after. I can completely dismantle my car into it's smallest parts and rebuild it without opening a book or resorting to overpriced diagnostics machines can you?
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 5537SG] #15438
05/26/05 02:22 PM
05/26/05 02:22 PM
the boonies
the boonies
An IC is not an IC. I work electronics EVERY DAY!!! I am an electrical engineer (since 1985). Ived worked at Hughes Aircraft in Radar Enngineering for 15 years and currently work a space electronics company as a reliability engineer. All I do is parts.
IC's come in so many different flavors it's ridiculous. they have different voltage requirements and have different tolerances to overvoltage. some work at 3.3v and will die at 7v. others work at 12v and will die at 30v. its all in what the technology is. (is it 1 micron, 2 micron or THE OLD STUFF).
what kind of metallization is it? what kind of circuit is it? Protection diodes? current limiting resistors??
there are so many variables.
the transistors in the electronic ignition can probably handle 60v. an ECU in a newer car is much less because as the die gets smaller, less voltage and/or current is required to get THOSE transistors to switch. They are MUCH more sensitive.
there are parts made to handle high power and those that arent. My job requires me to derate parts to mil standards and apply worst case conditions to see if they will survive in space. They are all different.
a transistor is NOT just a transistor.
Technology HAS changed. Our cars are extremely more tolerant to voltage flucuation and EMI than newer cars. They get screwed up so easily by power surges and or electrical noise.
I can run solid core spark plug wires on my car and truck because the electronics are not susceptibly to the electrical noise they produce yet it i drive close enough to a brand new caddy, I could probably blow its computer (exageration but close)
I am scheduled to run ANOTHER EMI test on electronics for the Joint Strike Fighter next month. Ive done this stuff for a long time.
those are my credentials and I am agreeing with most of what stumpy says.
you are talking NEW cars (95 and up). we are talking old cars.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: aarcuda] #15439
05/26/05 02:24 PM
05/26/05 02:24 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
The regulator still being connected and operational is what causes the field to remain energized, this causes the alternator to keep working, building up a charge with nowhere to go since the battery is no longer in the system
thats just a surge, thats not the issue
thats a serious mistake but only determental to the car with the dead battery. Its not relevant to this arguement. It causes the alternator to work full tilt til the battery is charged. An alternator is designed to keep a battery charged, not charge up a dead one. The result will often be a burnt rectifier. Sometimes they whistle. Most people get away with it though.
there is a possibility but minimal. Best not to do so.
no damage that youve seen immediatley. Seen it many times myself, and know of other knowledgeable mechanics that have. Becoming a bigger issue these days with body shops running down batteries then boosting them
Try it and tell me never. 400 is a tad high, but its possible. 200+ is more common! try it, keep your field energized, then disconnect the output wire on your alternator. Check the alternator output with a voltmeter. rev it up. Tell me how your readings wont cause troubles!! Just like I said earlier, try it with your battery charger. It works the same way!
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: aarcuda] #15440
05/26/05 02:26 PM
05/26/05 02:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Now that's some serious credentials.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: aarcuda] #15441
05/26/05 02:30 PM
05/26/05 02:30 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
ok so youre familiar with the concerns of electrostatic discharge then, good.
you know theres a possibility of damage, and youre familiar with EMI and such, great.
now you need to know what generates the power that causes them.
An IC is an IC, youre just talking about specifics of certain ones. They all consist of delicate electronic parts! Maybe you can ask some of your co employees, or can research this a little better. I assure you the point I make is true.
I gotta run out, I dont have time to continue this right now, but I will later.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: stumpy] #15442
05/26/05 02:30 PM
05/26/05 02:30 PM
the boonies
the boonies
I'm also a registered patent attorney if you guys want to invent something....
