68-70 Charger rear window channel patch? #154409
11/21/08 11:31 AM
11/21/08 11:31 AM
Bellevue, NE
Charger453 Offline OP
Bellevue, NE
I'm looking for the patch for the upper rear window channel for a 68-70 Charger. I can only find it at autobodyspecialt.com, but I could've sworn Year One carried it. I can't find it there or Paddock. Anyone?
Re: 68-70 Charger rear window channel patch? [Re: Charger453] #154410
11/25/08 01:19 AM
11/25/08 01:19 AM
Bellevue, NE
Bellevue, NE
Anybody? I know somebody knows somebody that has used one of these......
Re: 68-70 Charger rear window channel patch? [Re: Charger453] #154411
11/25/08 08:19 AM
11/25/08 08:19 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you could probably cut one out of a car at a yard. That's not something that's usually been removed.
Re: 68-70 Charger rear window channel patch? [Re: Mr.Yuck] #154412
11/25/08 10:13 AM
11/25/08 10:13 AM
Bellevue, NE
Bellevue, NE
I have yet to find one that is solid and probably never will on a parts car/yard find.
Re: 68-70 Charger rear window channel patch? [Re: Charger453] #154413
11/25/08 11:00 AM
11/25/08 11:00 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you talking about this??? try calling some yards out west.
Re: 68-70 Charger rear window channel patch? [Re: Mr.Yuck] #154414
11/25/08 01:48 PM
11/25/08 01:48 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
I ended up rebuilding mine piece by piece. It turned out pretty good.
Re: 68-70 Charger rear window channel patch? [Re: Charger453] #154415
11/25/08 06:48 PM
11/25/08 06:48 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Check out the work I did on this 68 Charger a few years ago, using a very similiar patch.
Re: 68-70 Charger rear window channel patch? [Re: DUSTER_340] #154416
11/25/08 06:49 PM
11/25/08 06:49 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
another picture
Re: 68-70 Charger rear window channel patch? [Re: DUSTER_340] #154417
11/25/08 06:51 PM
11/25/08 06:51 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
again another photo
Re: 68-70 Charger rear window channel patch? [Re: DUSTER_340] #154418
11/25/08 06:53 PM
11/25/08 06:53 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
You will most likely have to trim the ends and fill in the gaps with small patches, becuase of the compund surfaces in those corners, and be sure to check your window moldings as you are mocking this up.
