No mention of the exact CFM or size, but my engine is only 725hp....
Hi Randy,
Thanks for taking the time to fill out our online form.
As you probably already know, the SV1 is the best carb for your program.
Obviously you've already read about the SV1, but here's a link just in case:
http://www.prosystemsracing.com/svseries.html Our build time is about 4 days as of today.
For your combination the SV1 we would build will flow in the 1100 REAL cfm range, we will adjust it for the final best cfm rating when we are flowing it for your setup.
It typically makes about 10-15 more than a Dominator in your application and 15-35 more than a 4150.
The SV1 for your application is $1250.00 and shipping is only $18.00
If this works for you, just E or call with a credit card number when you're ready and we'll get it built.
Patrick James
727-490-5717
