Doing front end - right time for disc brakes? (budget?) #154322
11/21/08 12:32 AM
11/21/08 12:32 AM
Flint, MI
Gusteve Offline OP
I Love the Unicorn Song!!
Gusteve  Offline OP
Flint, MI
Hey all,
I'm going to order parts to re-do the front end of my 68 charger over the winter. I'm building it as a driver, not a performance car or show car. I'd like to eventually have disc brakes on the front. I had some scary situations in my last Charger that only had factory drums. (Everyone else on the road could stop WAY faster than I could).
Would it be less expensive to do discs now as part of a front end rebuild as opposed to adding them later? I realize the labor saving is a no-brainer, since I'll have the control arms and ball joints off. But would I save any money by doing a disc upgrade while I have the whole thing apart? i.e. - are there parts that I would buy while doing a standard front end upgrade that would not be necessary if I converted to discs down the road?
Also - I don't want to spend $2,000 on a disc kit. I think I've seen some for around $700. Should I be leary of the low-price kits?
Thanks!
Re: Doing front end - right time for disc brakes? (budget?) [Re: Gusteve] #154323
11/21/08 12:40 AM
11/21/08 12:40 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The parts remain the same the only real advantage is you won't have the beat on your new ball joints to seperate them from the spindle that will need to be replaced...You can do discs alot cheaper than $700.00...73-76 A body spindles typically sell for $100-$150.00 new rotors are $35.00 per side loaded calipers 40.00 per side Bearings & seals $60.00, hoses $30.00 = total less than $400.00 These are factory OE brake parts that are better than the OE 66-69 Disc parts, also better than the 70-71 OE brake parts....
Re: Doing front end - right time for disc brakes? (budget?) [Re: 1_WILD_RT] #154324
11/21/08 10:02 AM
11/21/08 10:02 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
I purchased spindles from a guy off ebay with a list of stock parts for the upgrade. Rotors, bearings, hoses, calipers, new master cylinder, and everything else for less than 400. Pm me if you want the info. On my site under suspension you can see the brakes and suspension. I did get the street strip kit from just suspensions, everything bolted up nice. Good luck
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: Doing front end - right time for disc brakes? (budget?) [Re: moepwr] #154325
11/21/08 08:42 PM
11/21/08 08:42 PM
Flint, MI
Gusteve Offline OP
Gusteve  Offline OP
Flint, MI
PM Sent
Re: Doing front end - right time for disc brakes? (budget?) [Re: Gusteve] #154326
11/22/08 12:42 AM
11/22/08 12:42 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Shop around. You can pick all the pieces for around $300-400. Aside from spindles and caliper brackets, everything else can be bought new/remanufactured from any parts store.
Re: Doing front end - right time for disc brakes? (budget?) [Re: Gusteve] #154327
11/22/08 10:14 AM
11/22/08 10:14 AM
Penguin Country
moepwr Offline
moepwr  Offline
Penguin Country
Email replied
Good luck
Re: Doing front end - right time for disc brakes? (budget?) [Re: moepwr] #154328
11/22/08 07:17 PM
11/22/08 07:17 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I am putting the SSBC kit (front disc brake kit) on my 69 Charger now.
I have the old stuff off,,,and have the new stuff on,,,the rotors,,calipers,,,,lines,,etc,,,,just have to put the MC on,,,,
I really like the kit,,,impressed with it,,,came with EVERYTHING,,,,didnt have to remove the spindles,,,
I was going to try and piece it together but am glad i got the kit....
total cost was $890 from JEGs to my door........
My car had drums all the way around ,,,and was SCARY...when it came to stopping,,,,,,,,,,cant wait to try out the disc brakes,,,,,,,,,,,
old..........
NEW>.....................
Re: Doing front end - right time for disc brakes? (budget?) [Re: 69CHARGERMD] #154329
11/23/08 01:52 AM
11/23/08 01:52 AM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
Did you replace the steel lines up to the proportioning valve, or just the flex line? Just curious what everyone else is doing?
Re: Doing front end - right time for disc brakes? (budget?) [Re: cudabitten] #154330
11/23/08 02:07 AM
11/23/08 02:07 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I never did on my west coast cars. They have been operational all their live though.
Do you have a car that has been non operational for a while? Sitting low on brake fluid can really mess things up. And back east its much more common to rust out brake lines. More moisture out there to get into the brake fluid too.
