Who can refinish the exterior of my manual Steering Box #1543180
12/03/13 04:22 PM
12/03/13 04:22 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
A few years ago I had Steer & Gear (Ohio) rebuild my manual steering box for my 1969 Roadrunner. However, they did not provide any service to refurbish the exterior of the steering box. The steering box, being all aluminum, has become quite tarnished. I am looking for someone to restore the natural aluminum finish back to my steering box, not polished, not painted, just the bright aluminum look. Does anyone one know of someone doing that type of work? The steering box components do not need to be rebuilt as they are fine. Your help would be greatly appreciated.
Re: Who can refinish the exterior of my manual Steering Box [Re: Imrare] #1543181
12/03/13 06:37 PM
12/03/13 06:37 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If all you want is a stock looking finish try hitting it with some Alum-i-prep and very fine steel wool just to get the dirt and corrosion off of it.
Re: Who can refinish the exterior of my manual Steering Box [Re: Stanton] #1543182
12/03/13 07:25 PM
12/03/13 07:25 PM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
You could try this trick at home if you have the time and a compressor.
http://www.aircooledtech.com/tools-on-the-cheap/soda_blaster/
Bob
Re: Who can refinish the exterior of my manual Steering Box [Re: it's Bob] #1543183
12/04/13 12:36 AM
12/04/13 12:36 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Now that is pretty trick.
I have heard that air conditioner coil cleaner works great on aluminum. I haven't used it so I would try it on the back side of the box or an old valve cover first to see if it gives the results you are looking for.
Careful, your character's showing!
Re: Who can refinish the exterior of my manual Steering Box [Re: it's Bob] #1543184
12/04/13 12:46 AM
12/04/13 12:46 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
Bob
I own a media blasting business and we do soda blasting. soda will not remove the dark spots left from oil cooking. if you want a uniform color you would need a abrasive media or a chemical. we do lots of aluminum bike engines and allways warn the customers of that before hand.
household soda and blasting soda are not the same size either. your better getting animal grade soda from your local feed store (still slow but a little faster)
Re: Who can refinish the exterior of my manual Steering Box [Re: chrisf] #1543185
12/04/13 04:16 PM
12/04/13 04:16 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
We have a local media blast business here as well, I haven't checked with them yet because actually, I thought the steering box housing would have to be put in a "shot tumbler" to restore it to new looking condition. How are the Alternator Housings done? Is they "soda" blasted? Any time I've checked out a "remanufactured" alternator at the auto parts store, the housing looked like brand new. I'm sure the same process would work for my Steering Box housing as well. Your thoughts on that?
Re: Who can refinish the exterior of my manual Steering Box [Re: Imrare] #1543186
12/04/13 04:54 PM
12/04/13 04:54 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The reman alternators are probably blasted but that is NOT the correct finish. As soon as you blast a part, you've lost it's original appearance.
Also check out this link. It was mentioned in another post a couple days ago.
http://www.rustoleum.com/product-catalog/consumer-brands/auto/paint-chemicals/rust-stripper/
Re: Who can refinish the exterior of my manual Steering Box [Re: burdar] #1543187
12/04/13 08:44 PM
12/04/13 08:44 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Really? Obviously, the housing is not rusty (being aluminum). Have you by chance tried this product on aluminum and had success with it?
I tried an Eastwood product a few years ago that was advertised to bring back the natural finish of aluminum...it didn't work.
Re: Who can refinish the exterior of my manual Steering Box [Re: Imrare] #1543188
12/04/13 11:15 PM
12/04/13 11:15 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I have not tried it. It was mentioned in a thread on how to bring back the natural finish on a carb body. There was also an article on refinishing alternator cases and that product was mentioned. That's all I know.
Re: Who can refinish the exterior of my manual Steering Box [Re: burdar] #1543189
12/05/13 10:10 AM
12/05/13 10:10 AM
PA
BTTG Offline
BTTG  Offline
PA
the article on restoring aluminum parts was in the February 2013 issue of Mopar Action
http://www.moparaction.com/Next/history/feb2013.html
Re: Who can refinish the exterior of my manual Steering Box [Re: BTTG] #1543190
12/05/13 04:26 PM
12/05/13 04:26 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Okay then, I'll see if I can find a copy still available. Thank you.
