How to remove steering box #154280
11/20/08 11:14 PM
11/20/08 11:14 PM
Oklahoma City, OK
moposcar Offline OP
moposcar  Offline OP
Oklahoma City, OK
How do you disconnect the steering box from the column on a 56 Coronet? Where is the secret "keeper"? We have undone all the bolts, and the box is loose on the column, but it won't slide on off.
Thx.
Re: How to remove steering box [Re: moposcar] #154281
11/21/08 02:41 PM
11/21/08 02:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Manual or power?
Re: How to remove steering box [Re: John_Kunkel] #154282
11/21/08 04:01 PM
11/21/08 04:01 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
My 40 is all one peice. The worm is on the end of the column shaft. They used this in trucks thru the early sixties.
Re: How to remove steering box [Re: John_Kunkel] #154283
11/21/08 11:11 PM
11/21/08 11:11 PM
Oklahoma City, OK
moposcar Offline OP
moposcar  Offline OP
Oklahoma City, OK
It is manual. If it is one piece, do you just have to cut it? I guess you could take the shaft out by removing all the lock washers, etc, from inside the steering column?
Thx.
Re: How to remove steering box [Re: moposcar] #154284
11/22/08 02:42 AM
11/22/08 02:42 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Have you removed the steering wheel? It has to come off before the shaft will seperate from the column. Gene
Re: How to remove steering box [Re: poorboy] #154285
11/23/08 11:44 AM
11/23/08 11:44 AM
Oklahoma City, OK
moposcar Offline OP
moposcar  Offline OP
Oklahoma City, OK
Yeah, I have removed the steering wheel, however I haven't messed with any of the lock washers/rings inside the column. I know how the shafts come out on the late 60's, early 70's cars. This one is just different. So I take it that the shaft comes out through the bottom (with the steering box).
Re: How to remove steering box [Re: moposcar] #154286
11/23/08 12:08 PM
11/23/08 12:08 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: How to remove steering box [Re: RodStRace] #154287
11/24/08 12:17 AM
11/24/08 12:17 AM
Oklahoma City, OK
moposcar Offline OP
moposcar  Offline OP
Oklahoma City, OK
Yeah, that's it.
