I had an '02 also. As I remember the lift pump pressurizes the filter and excess pressure bleeds off and returns to the fuel tank in a separate line. You may have a leak in the return line. If you have not yet done it, now would be a great time to relocate the lift pump to the frame rail, they work a lot better as a pusher than a puller and will live longer away from the vibration of the engine. Leave the bracket on the engine, it covers a hole that needs to be sealed. Buy the Vulcan kit from Geno's Garage in Georgia. The lift pumps were attached to the engine assembly to benefit the production line, not the owners of the trucks. Geno's can probably help you with an aftermarket filter if your's is bad.
![](/ubbthreads/images/graemlins/thumbs.gif)
Check in with the turbo diesel register for more tips.
