Dash pad bolts #1542495
12/01/13 09:42 PM
12/01/13 09:42 PM
Northern IL
meathead66 Offline OP
Northern IL
How are the dash pad bolts installed in the dash pad? It looks
like some type of black goo on a 69 Dart used like glue. Is
it available somewhere? It has to get pretty hard/solid to
hold the pad down
Re: Dash pad bolts [Re: meathead66] #1542496
12/02/13 10:17 AM
12/02/13 10:17 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
It's always been plain nuts on the threads an two small bolts on the ends. Never had a glue or anything else.
Re: Dash pad bolts [Re: moparpollack] #1542497
12/02/13 11:00 AM
12/02/13 11:00 AM
Northern IL
Northern IL
It's missing the 2 on the ends. How do they stay on the pad?
Re: Dash pad bolts [Re: meathead66] #1542498
12/02/13 11:46 AM
12/02/13 11:46 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My 68 uses studs except for the two ends. A screw is used there.
Post a picture of what you are talking about. If you are missing some of the studs, maybe you can use a larger screw in those places. Make sure to have a spacer behind it so you don't over tighten it.(the studs on my 68 use spacers so you can't over tighten the nuts)
Re: Dash pad bolts [Re: burdar] #1542499
12/02/13 07:46 PM
12/02/13 07:46 PM
Northern IL
Northern IL
I think I got it. Didn't see the end holes. Must be a nut
buried in there to screw into?
