What's a easy way to strip manifold for painting/ #154232
11/20/08 08:43 PM
11/20/08 08:43 PM
BDW Offline OP
BDW  Offline OP
I don't want to have it sandblasted. Is there a good / easy way to strip paint from an exhaust manifold?
Something I can pick up locally?
Thx
Re: What's a easy way to strip manifold for painting/ [Re: BDW] #154233
11/20/08 09:17 PM
11/20/08 09:17 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Yes, sandblasting. If you want to get it down to bare metal for best paint adhesion, sandblast it.
Why do you not want to have it sand blasted, if I may ask?
Re: What's a easy way to strip manifold for painting/ [Re: BDW] #154234
11/20/08 09:19 PM
11/20/08 09:19 PM
Kirkland, Washington
Pacnorthcuda Offline
If blasting is out of the question I would use aircraft stripper---available at most auto parts stores.
Re: What's a easy way to strip manifold for painting/ [Re: Pacnorthcuda] #154235
11/20/08 09:25 PM
11/20/08 09:25 PM
BDW Offline OP
BDW  Offline OP
2 reasons, I was quoted $40, which seems high and more importantly to will take 2 extra days. Don't want to drop it off and then have to go pick it up.
Re: What's a easy way to strip manifold for painting/ [Re: BDW] #154236
11/20/08 10:32 PM
11/20/08 10:32 PM
IA. ,USA
dodgeboychris Offline
IA. ,USA
Easy-Off oven cleaner, strips down to bare then looks new.
Re: What's a easy way to strip manifold for painting/ [Re: dodgeboychris] #154237
11/20/08 11:18 PM
11/20/08 11:18 PM
Tucson AZ
2
2cudabuck Offline
2cudabuck  Offline
Tucson AZ
Second the oven cleaner, just make sure to get the NO HEAT version, but it will take it to bare metal and look new, used it many times. BTW, you can mask anything you dont want to get stripped with tin foil.
Buck 67 273 Dart GT 69 RT 440 Charger (SWEET!) 70 318 Cuda 74 Cuda Packin a 426 roller Hemi
Re: What's a easy way to strip manifold for painting/ [Re: 2cudabuck] #154238
11/21/08 06:38 AM
11/21/08 06:38 AM
BDW Offline OP
BDW  Offline OP
Easy Off sounds good, what process do you use? Or just follow directions like for an oven?
Re: What's a easy way to strip manifold for painting/ [Re: BDW] #154239
11/21/08 06:13 PM
11/21/08 06:13 PM
Sacramento, CA
K
Kirk_Ingram Offline
super street
Kirk_Ingram  Offline
super street
K
Sacramento, CA
Oven cleaner works well, sandblast is the best way to go. Yeah you mentioned you don't want to do that but...it is the best way to go. Blast it, and it's ready to be coated.
If you already have an air compressor, you can get a cheap-O sandblaster from Harbor Freight.
For Easy Off method; put the parts in the sun for about an hour (just enough to warm up, DON'T cook it!), spray down, wait 5-6 minutes, quick scrub with a disposable brush, turn over, spray down, scrub again, wait 6-8 minutes, rinse with HIGH water pressure. Repeat if necessary.
You will have to prep the part for paint. Clean, clean, etc.
Death or Glory...it's just another story.
Re: What's a easy way to strip manifold for painting/ [Re: BDW] #154240
11/22/08 05:06 PM
11/22/08 05:06 PM
GMP440 Offline
GMP440  Offline
Does the Easy Off oven cleaner take the rust away?
Re: What's a easy way to strip manifold for painting/ [Re: GMP440] #154241
11/22/08 06:24 PM
11/22/08 06:24 PM
BDW Offline OP
BDW  Offline OP
Well, I tried the easy off, and it doesn't work very good. It really didn't do anything at all.
I guess sandblasting is the best solution.
And no, it doesn't remove rust. I'll hit it will some Ospho before painting.
Re: What's a easy way to strip manifold for painting/ [Re: BDW] #154242
11/22/08 06:43 PM
11/22/08 06:43 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
shake n bake baby.. thats what my local NAPA does. they have a system that bakes it, then is shot blasted, then air blasted. comes out sooo clean. even a rust bucket comes out looking new..
I am truckless..
