Brake Prop. Valve #1541937
11/30/13 07:26 PM
11/30/13 07:26 PM
Detroit
Got2Gnow Offline OP
Got2Gnow  Offline OP
Detroit
I have a '71 Dart Swinger I just put the SSBC front disc brake kit on. It came with an adjustable proportioning valve (see pic), but I'm unsure as to where to install this valve. The directions are not very clear. Can anybody help direct me? Do I put it between the master cylinder and the rear brake lines?
Re: Brake Prop. Valve [Re: Got2Gnow] #1541938
11/30/13 07:41 PM
11/30/13 07:41 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
It goes between the rear brake line and the distribution block. Try to put it close to the distribution block.
Re: Brake Prop. Valve [Re: 71birdJ68] #1541939
11/30/13 09:25 PM
11/30/13 09:25 PM
Detroit
Got2Gnow Offline OP
Got2Gnow  Offline OP
Detroit
OK, so not immediately out of the master cylinder? But, anywhere in the rear brake line as close to the distribution block as possible?
Re: Brake Prop. Valve [Re: Got2Gnow] #1541940
11/30/13 09:29 PM
11/30/13 09:29 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Yes, so you can adjust it.
Re: Brake Prop. Valve [Re: Got2Gnow] #1541941
11/30/13 09:35 PM
11/30/13 09:35 PM
Yes between the rear splitter/prop valve and the rear axle in series in that line. If you put it in just after the M/C it would reduce the psi to the fronts and the rears simultaneously & you want to be able to reduce the psi to the rears only as needed to keep them from locking up & you want the fronts to lock up just before the rears on a hard stop
Re: Brake Prop. Valve [Re: RapidRobert] #1541942
11/30/13 10:11 PM
11/30/13 10:11 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
why would it effect the fronts?
Re: Brake Prop. Valve [Re: 05dakota] #1541943
11/30/13 10:41 PM
11/30/13 10:41 PM
If you put the adj prop valve just downstream of the M/C it would reduce the psi to everything downstream from there which would include the fronts
Re: Brake Prop. Valve [Re: RapidRobert] #1541944
11/30/13 11:34 PM
11/30/13 11:34 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
but he would have 2 lines unless its a 66 or older setup
Re: Brake Prop. Valve [Re: 05dakota] #1541945
11/30/13 11:54 PM
11/30/13 11:54 PM
You ARE correct, I totally spa ced that . the only issue I could see with it there in the M/C rear brake line up front would be if the reduction in the one line would possibly let the electric brake warning light in the prop valve to shift over to the low psi side & go on like it does with a leak but I ain't sure if there'd be enough of a reduction in psi for that to happen & it's beyond my skill level to go any further with that. All I can add is traditionally they are put in the rear line so I'm thinking that there must be a reason for that
Re: Brake Prop. Valve [Re: RapidRobert] #1541946
12/01/13 12:44 AM
12/01/13 12:44 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I my barracuda race car I put it in the line to the rear brakes, I ran new lines and the first line from the master cylinder cam out at the underside of the drivers seat next to the rocker panel. I drilled a hole in the floor and installed it there. Actually it worked out well as it was easy to adjust there, out of the way and served as a coupling to continue to the line to the back.
