Big inch short block
#1541786
11/30/13 02:00 PM
11/30/13 02:00 PM
Posts: 30 visalia,ca,USA
bluebird69
visalia,ca,USA
Where's the best place to get a 500" plus short block
TAKES A MOPAR TO CATCH A MOPAR
Re: Big inch short block
[Re: bluebird69]
#1541789
11/30/13 11:19 PM
11/30/13 11:19 PM
RapidRobert
I'm assuming that there ain't no local Mopar heads there (or nearby) that you are comfortable with that would put some love & care into an eng for you & get everything spot on/dead on/perfect. As you know you need someone conscientious which means someone whose outstanding characteristic is patience & who has a high tolerance for frustration in addition to a high skill level. Good luck & holler how it turns out
