727 full manuel transmission ??? #1541749
11/30/13 03:46 AM
11/30/13 03:46 AM
Mt Evelyn , Vic Australia
dartcharger Offline OP
Virgin Fluff
Virgin Fluff
The tran's that came with the dart was already rebuilt, i assumed it was just a stock rebuild as the seller did'nt brag about the goody's that it had been built with. today while getting ready to bolt it to the motor before i install it i noticed the top of the shift point had been chopped off. It's the shaft that the kick down arm would bolt to, any idea's what's up with that....why would some one do that? (see attch)
Re: 727 full manuel transmission ??? [Re: dartcharger] #1541750
11/30/13 09:15 AM
11/30/13 09:15 AM
Western PA
O
OldMoparMan Offline
OldMoparMan  Offline
O
Western PA
Since you should at least pull the pan to change the filter and oil you can see what has been done to the throttle pressure arm and valve body.
By the looks of the line connection and shift arm that tranny has been sitting for a while so a rebuild might be in order.
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
Re: 727 full manuel transmission ??? [Re: OldMoparMan] #1541751
11/30/13 09:31 AM
11/30/13 09:31 AM
Maryville tn
67coronetman Offline
Maryville tn
I agree i would look it over and pull the pan do it now before you put it all in the car now is the time.!
Old car are me......
Re: 727 full manuel transmission ??? [Re: 67coronetman] #1541752
11/30/13 12:32 PM
11/30/13 12:32 PM
Beans Cove Pa
Bumbalawski Offline
Bumbalawski  Offline
Beans Cove Pa
Some valve body builders cut the "kickdown" shaft off on their manual valve bodies.
Re: 727 full manuel transmission ??? [Re: Bumbalawski] #1541753
12/01/13 03:11 PM
12/01/13 03:11 PM
Virgin Fluff
Virgin Fluff
That's the sort of thing i was wondering about, ill get some one that knows what their looking at to check it out for me. thanks for everybody's input.
Re: 727 full manuel transmission ??? [Re: dartcharger] #1541754
12/01/13 03:43 PM
12/01/13 03:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When building a MVB I always cut the shaft off to avoid confusion with a full auto VB. There really isn't any other reason to do it.
