Anyone can Recommend a Good Cooling System Stop Leak?
#1541704
11/30/13 12:06 AM
11/30/13 12:06 AM
Posts: 145 North East
MaxHeadroom
North East
Never had much luck with these, well, maybe once. Only have used Bars Leak, I think. I have a truck, engine is tucked back, one of the metal heater hose assemblies has sprung a leak. Only way to get to it is to pull off everthing on top of engine and passenger side. My other cars are not movable in the garage, so would have to do this in the street, Lol, too cold for that. I have seen some expensive brands, Moroso Ceramic, Blue Devil ($60) and a few others. Need something to maybe hold me by until I have a place to do this. Mechanics want several hundred because everything has to be moved. What have you tried that you can recommend? Thanks.
BTW... tried a $10 bottle of Bars Heater Core, did nothing.
Re: Anyone can Recommend a Good Cooling System Stop Leak?
[Re: MaxHeadroom]
#1541705
11/30/13 12:20 AM
11/30/13 12:20 AM
RapidRobert
I know it's winter but is there anyway to bypass it (or at least for awhile). Good luck
[Re: AARCONV]
#1541708
11/30/13 11:25 AM
11/30/13 11:25 AM
Posts: 10,735 North Dakota
6PakBee
North Dakota
Texas? Cold? I'm changing the fuel filters on my Massey this morning. 25 above and cloudy. But anyway, if one of your metal core pipes has sprung a leak, you have a definite possibility of a gross failure. I agree with the others, if you can't fix it, bypass it. Now speaking as someone who has done this, get used to driving with your window down and have an ice scraper handy because the inside of the windshield frosts over from your breath. No fun.
[Re: MaxHeadroom]
#1541710
11/30/13 11:47 AM
11/30/13 11:47 AM
Posts: 905 SD
zrxkawboy
SD
Conklin's Dike is the best, and will not clog anything.
You said you already added one kind of stop leak. No matter what you try now, you need to flush the system first. Mixing two kinds of stop leak in a system is asking for trouble.
It's Swifty! Swifty, you toad sucker!
[Re: zrxkawboy]
#1541712
12/02/13 02:31 AM
12/02/13 02:31 AM
Posts: 5,948 British Columbia
chrisf
British Columbia
yep, dyke (proper spelling) works great. we use it on the big truck stuff with 100% leak stoppage.
[Re: chrisf]
#1541713
12/02/13 07:23 PM
12/02/13 07:23 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Learned a long time ago, stop leak only causes the next weak point to leak. Can you maybe bypass it with a long heater hose so that you still get heat then replace it later?
