Advice for protecting a southern truck from road salt #154156
11/20/08 07:56 PM
11/20/08 07:56 PM
b5rr Online content OP
b5rr  Online Content OP
Bought a used Ram truck from down south earlier this year. It's got alot of paint chips on the rockers and I'm afraid of what the road salt here in the Midwest will do to it. I'm installing mudflaps but not sure that will be enough. Does anyone still make that textured clear chip guard that used to be put on some vehicles? Any tips would be appreciated. Thanks
Re: Advice for protecting a southern truck from road salt [Re: b5rr] #154157
11/20/08 08:03 PM
11/20/08 08:03 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Move to a climate that can support human/vehicle life or park it. Drive in salt, it will rot, period.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Advice for protecting a southern truck from road salt [Re: b5rr] #154158
11/20/08 08:10 PM
11/20/08 08:10 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
my 02 dakota has rust holes in tail gate.
Re: Advice for protecting a southern truck from road salt [Re: 05dakota] #154159
11/21/08 12:19 AM
11/21/08 12:19 AM
The salt mixture here is extremely corrosive & once it starts to rust it has amazed me on how fast it will spread & it is very aptly named cancer. I just switch to a beater for the winter.
Re: Advice for protecting a southern truck from road salt [Re: b5rr] #154160
11/21/08 12:57 AM
11/21/08 12:57 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Send it back to the south.
Re: Advice for protecting a southern truck from road salt [Re: goldmember] #154161
11/21/08 01:01 AM
11/21/08 01:01 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Or park it & drive a beater...
Re: Advice for protecting a southern truck from road salt [Re: goldmember] #154162
11/21/08 01:02 AM
11/21/08 01:02 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
If you absolutely have to drive it in the winter, the best I've seen is the dripless oil undercoating they use in Canada. I'm sure it is used in some states, just don't know which ones, and certainly not Michigan.
Re: Advice for protecting a southern truck from road salt [Re: MarkZ] #154163
11/21/08 01:05 AM
11/21/08 01:05 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Just cover it in hot tar,maybe undercoat everything?
Re: Advice for protecting a southern truck from road salt [Re: goldmember] #154164
11/21/08 01:33 AM
11/21/08 01:33 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Never gonna wash it?
Re: Advice for protecting a southern truck from road sa [Re: gamagoat6x6] #154165
11/21/08 02:04 AM
11/21/08 02:04 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Do not agree with that at all.
Oil spray yearly. This will prevent rust. It is messy, costs almost $100 per year, rough on your parking spot for a while but it works great. Oily metal will not rust.
It's is not the cure all, end all. You can't oil EVER"YTHING and EVERYWHERE.
Some also gets washed off by the slush splashing off your tires but it will slow the cancer to almost nothing.
Re: Advice for protecting a southern truck from road salt [Re: b5rr] #154166
11/21/08 07:29 AM
11/21/08 07:29 AM
Wow, lots of smart #%#$ answers I never thought about. Thanks for those who gave a genuine response. I'm not so much worried about the underside, I won't be driving it daily and I will wash it more than regularly. I was really looking to protect the lower 1/4 of the truck on the exterior with some kind of clear chip guard and though maybe someone could recommend what they've used.
Re: Advice for protecting a southern truck from road sa [Re: b5rr] #154167
11/21/08 09:28 AM
11/21/08 09:28 AM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Up here In Toronto we have a good product called Krown rust control,
it is a thin oil that they spray all thru the inside of all the panels and the underside.
I have used it on my 89 Dodge van and it still has no rust.
The good thing about the thin oil is that it creeps into all the seams of the metal where water likes to get into and never dry and starts to rust.
The oil will prevent that from happening.
If the oil or rust treatment is too thick it will only create a bridge and in the cold will get harder and water can sit under it and cause rust.
I have seen that many times on cars where it rusted under the waxy spray stuff.
Try to find out if they have any dealers in the states or look for thin over thick.
Don't use old motor oil.
Re: Advice for protecting a southern truck from road sa [Re: boydsdodge] #154168
11/21/08 09:30 AM
11/21/08 09:30 AM
boydsdodge Offline
boydsdodge  Offline
Re: Advice for protecting a southern truck from road sa [Re: boydsdodge] #154169
11/21/08 11:54 AM
11/21/08 11:54 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You could always spray on rocker guard on the bottom 12" of the truck. It's that textured spray on stuff, usually dries to a semi-gloss black. I've seen it used lots on vehicles that are chipped up on the bottom or vehicles that someone did some bondo rust repair and didn't want to paint the whole vehicle. Very durable stuff.
Re: Advice for protecting a southern truck from road salt [Re: b5rr] #154170
11/21/08 12:04 PM
11/21/08 12:04 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Aside from factory undercoating, Rustcheck works, and you can do it yourself. Be sure everything is bone dry when you apply it.
Re: Advice for protecting a southern truck from road salt [Re: b5rr] #154171
11/21/08 12:20 PM
11/21/08 12:20 PM
N. Arkansas
STREETSHAKER Offline
N. Arkansas
I lived in chicago many years before moving south and found that frequent washing at car washes will hasten the rust problem. Most car washes merely filter the water used due to the expense of high water bills so the salt from every other car gets into the water you are spraying on your vehicle. Also, the salt water brew you are spraying will get into every space of your vehicle that normal driving would not such as inside doors, under the hood ect. Very few car wash locations use fresh water but they do exist. They advertise the fact that they use only fresh water and they are very expensive by comparison. To prevent rust you would need to follow the advice given about the oil treatments and stay away from regular car wash facilities. Sorry to say, the road salt will still cause you problems but you can slow down the process.
Re: Advice for protecting a southern truck from road salt [Re: STREETSHAKER] #154172
11/21/08 08:13 PM
11/21/08 08:13 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Here in upstate NY the oil treatment is called Rust Stop and it works. I have used it on pre-owned vehicles with great success.
Re: Advice for protecting a southern truck from road salt [Re: b5rr] #154173
11/21/08 08:17 PM
11/21/08 08:17 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
There is only one guarantee. If you drive it, it will rot out. If you park it in the same garage as you park your daily vehicle, it will rot out.
This is the land of the free because of the brave
Re: Advice for protecting a southern truck from road salt [Re: b5rr] #154174
11/21/08 09:13 PM
11/21/08 09:13 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
The first place you should be worried about is the underside! Thats where the rust starts and by the time it starts bubbling the paint, it's too late. You need to start on the underside first, then give the paint a good polish. Even that wont stop it from rusting. Good luck.
Re: Advice for protecting a southern truck from road salt [Re: krw71ragtop] #154175
11/21/08 10:08 PM
11/21/08 10:08 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Fix any chipped paint areas, making sure there is no bare nor primered metal exposed.
Interesting info regarding car washes above. Even if the car wash uses clean water (which is good), if the temp gets below freezing and there's water in places you don't want it (panel seams, inside doors, etc.), it'll freeze and expand, exposing fresh metal. This is usually how you get rusting from the inside out, especially on door bottoms and around wheel well arches- paint rarely ever gets applied there when the car is painted at the factory, so it's already a weak spot. If you do wash it in very cold weather, dry it as best you can, and if you have a garage to park it in, do it...even if it's not heated.
My '90 Astro's body has held up very well after driving through three WI winters so far. Native WA state van 'til '04, it was 99% rust free, and despite some roof rust starting, it is still in great shape. I'll be honest, I don't wash it in winter unless we get a 40*+ day on a weekend when it can dry in the sun, but I take care of any chips and make sure there's no bare metal exposed.
Remember, it's not the salt that causes rust, but rather bare metal and water in the presence of oxygen. Does salt accelerate areas that have started to rust? Heck yeah it does, but the freeze/thaw cycles in winter are the real enemy.
