what is the difference between RB and hemi hyd lifters? #1541510
11/29/13 11:23 AM
11/29/13 11:23 AM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Some manufacturer's show a different hydraulic flat tappet lifter for hemis than wedge and some show the same part #.Some show a different lifter for pre 67 wedge engines and show that as the same lifter for hemis(the pre 67 wedge part #).?
Re: what is the difference between RB and hemi hyd lifters? [Re: ogopogo] #1541511
11/29/13 11:39 AM
11/29/13 11:39 AM
Some manafacturer's show a different hydraulic flat tappet lifter for hemis than wedge and some show the same part #.Some show a different lifter for pre 67 wedge engines and show that as the same lifter for hemis(the pre 67 wedge part #).?
1967 was a transition year for Mopar motors on lifter pushrod cup sizes, 1966, and probally some early 1967 motors, had 1/4 inch ball cups, 1967 and later switched to 5/16 ball. In 1969 when the 440 6 paks motors came out Mopar had those cams ground on a low taper angle with matching hydraulic lifters,they also had the cams ground on 3 bolt cores and used the street Hemi double roller timing sets In 1970 when Mopar switched the 426 Street Hemis to hydraulic camshafts they evidentily used those lifters in them also IHTHs
Re: what is the difference between RB and hemi hyd lifters? [Re: Cab_Burge] #1541512
11/29/13 12:36 PM
11/29/13 12:36 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
so is there any reason at all you could not use 68 up wedge lifters on a hemi camshaft?
Re: what is the difference between RB and hemi hyd lifters? [Re: ogopogo] #1541513
11/29/13 12:38 PM
11/29/13 12:38 PM
It depends on if the Hemi cam has low taper lobes or not Go with the cam makers brand of lifters
Re: what is the difference between RB and hemi hyd lifters? [Re: Cab_Burge] #1541514
11/30/13 12:43 AM
11/30/13 12:43 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
It doesn't make any difference but for the record there were no 3 bolt cams or double roller timing chains in the 69 A12 440-6 cars. The 6 Pak's came with the same nylon timing gear as all other 440's.
Re: what is the difference between RB and hemi hyd lifters? [Re: RoadRunnerJD] #1541515
11/30/13 11:20 AM
11/30/13 11:20 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
But the '70 440-6 engines came with the double roller chain and gears, didn't they. I am sure I was the first one inside my old Cuda's engine and it had them.
Master, again and still
Re: what is the difference between RB and hemi hyd lifters? [Re: DaveRS23] #1541516
11/30/13 12:34 PM
11/30/13 12:34 PM
Warrenton, VA
Warrenton, VA
Yes, it came on them in 1970. You could usually order aftermarket cams with 1 or 3 bolts. I would always order 3 bolt cams so that I could use the roller timing gear.
Re: what is the difference between RB and hemi hyd lifters? [Re: RoadRunnerJD] #1541517
11/30/13 03:17 PM
11/30/13 03:17 PM
I would bet money that they did come with the three bolt cam cores and the low taper lifters, I know one or two,(I didn't see in the other guys motor when he change his cam to a blueprinted cheater cam, but the new one was a three bolt and he said he reused the stock timing set and chain do to its low use when he started racing it ) SO CA racer that bought thier cars new and they came with the three bolt cam and timing set from Ma Mopar. Hotrod or Car Craft did a feature on the six pak cars in mid to late 1969 and they quoted the same details on the motors then I bought a 1970 V code Charger used, it had a warrenty block in it with a single bolt cam and timing set with the big rods and external balancer, the dealer reused the same clutch and flywheel that came in the car when replacing the motor. Lots of things occurred in production that shouldn't have or wasn't documented at that time until later, many mistakes(like a 350 HP motor being installed in a R/T or Magnum HP car )in cars went out the door undetected
Re: what is the difference between RB and hemi hyd lifters? [Re: ogopogo] #1541518
11/30/13 03:18 PM
11/30/13 03:18 PM
Clean out your inbox and PM me back when you do
Re: what is the difference between RB and hemi hyd lifters? [Re: DaveRS23] #1541519
11/30/13 03:44 PM
11/30/13 03:44 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
I "went through" a friends 70' Challenger 6 pack motor and it had a 3 bolt cam and a double roller chain and gears. Pretty sure it was untouched before me.
Re: what is the difference between RB and hemi hyd lifters? [Re: pacifica] #1541520
11/30/13 04:00 PM
11/30/13 04:00 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
I have the original set of lifters from my 1970 hemi motor that I replaced in 1983. If you need any measurements, I can do....
Re: what is the difference between RB and hemi hyd lifters? [Re: pacifica] #1541521
11/30/13 05:11 PM
11/30/13 05:11 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Pacifica,thanks for posting that pic,big help! if its convienient can you measure base to pushrod cup dimension? I measured a bunch of lifters yesterday and found it easier/more accurate with a 3/8 ball bearing sitting in the cup.The lifters all had different dimensions with the comp 824 being significantly shorter,causing my problems.If I use the comp 822 lifters I am good to go because they are taller but they are listed for 68 up wedge motors.
Can anyone tell me how I can id whether or not my comp 278 has the low taper lobes or not?
How can you tell if lifters are low taper or not?
Re: what is the difference between RB and hemi hyd lifters? [Re: ogopogo] #1541522
11/30/13 06:50 PM
11/30/13 06:50 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
The lifter "body height" is 1.832".
I can't find a 3/8" ball around here. I'll have to get one and then measure it.
Re: what is the difference between RB and hemi hyd lifters? [Re: ogopogo] #1541523
11/30/13 07:18 PM
11/30/13 07:18 PM
I tried to respond to your PM this morning but it says you've exceeded your PM limits, clean out your in box Try calling Comp on Monday and ask them if there lobes are standard taper or low taper and then ask them about the two different part # on those two lifters to see if you can use them with your pushrods or not. Remember the pushrod ball sizes needs to match the lifter cup sizes also, 1/4 inch ball in a 1/4 lifter cup, 5/16 and 5/16 together
Re: what is the difference between RB and hemi hyd lifters? [Re: Cab_Burge] #1541524
11/30/13 07:54 PM
11/30/13 07:54 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
Thanks guys,got that inbox cleaned too!
Re: what is the difference between RB and hemi hyd lifters? [Re: ogopogo] #1541525
11/30/13 10:42 PM
11/30/13 10:42 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
When I ordered my Hemi Hyd cam and lifters TIM at FHO said the height of the cups are different in the lifter body
Just something to consider checking
Re: what is the difference between RB and hemi hyd lifters? [Re: pacifica] #1541526
12/01/13 09:24 PM
12/01/13 09:24 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
So I picked up a 3/8" steel ball at the hardware store.
The steel ball measures .375".
With the steel ball in the lifter, they together measure 1.922"
Re: what is the difference between RB and hemi hyd lifters? [Re: pacifica] #1541527
12/01/13 09:35 PM
12/01/13 09:35 PM
That measurement tells me that the effective length (bottom of the lifter to the bottom of the pushrod cup) of that lifter is 1.547 using the 3/8 ball bearing instead of a 5/16 diameter bearing Do you know if that is a later, 1967 and later, 5/16 lifter cup or is it one of the 1966 and earlier lifters with the 1/4 inch lifter cup seats in them
Re: what is the difference between RB and hemi hyd lifters? [Re: Cab_Burge] #1541528
12/01/13 11:40 PM
12/01/13 11:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cab, are you taking in to that that the ball will
be lower in the cup with the 5/16 and not just the
diameter difference
To the OP... if you were to say the same year engine
the lifters are the same... never knew why they had
different P/N but the measurements were the same...
I have used B RB lifters in my small blocks on
different cams... all of them were roller lifters
Re: what is the difference between RB and hemi hyd lifters? [Re: MR_P_BODY] #1541529
12/02/13 05:27 PM
12/02/13 05:27 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
FYI,
i spoke to comp and tim banning this am and both said that the comp 822 and 824 are interchangeable.Tim did say he has gotton away from using hyd flat tappets because there are so few options these days with lifters and the few that are available have noise and QC issues
