big block rocker shaft wear? #1541365
11/28/13 11:21 PM
11/28/13 11:21 PM
Dayton, OH
I
idriveagremlin Offline OP
I
Dayton, OH
I have a mild 383 with PRW aluminum rocker arms 1.6 ratio. The cam is a Comp Thumper style hydraulic cam nothing radical. The heads are alum. 440 source. The right side of the engine seemed a bit noisy to me so I pulled the rocker shaft off and noticed the bottoms of the rocker arms were making slight contact with the valve spring retainers.
I have a pic of the wear. They are pretty badly grooved but the rocker bearings seem okay. Oiling does not seem to be a problem. This combo was in the car when I bought it.
I am just not sure if I should buy new shafts and try again with the rockers ground for clearance or just try a different set of rockers and shafts all together?
Re: big block rocker shaft wear? [Re: idriveagremlin] #1541366
11/29/13 12:00 AM
11/29/13 12:00 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Is the left side worn as bad? Are the oil holes drilled in a straight line with bolt holes that hold the shaft to the head?
Off hand I would say the shafts aren't hard enough for the type of rockers that are on them.
Re: big block rocker shaft wear? [Re: idriveagremlin] #1541367
11/29/13 12:43 PM
11/29/13 12:43 PM
When in doubt, change them all out Your rockers rubbing on the retainers had to put unforseen pressures on the rockers and shafts so why take a chance on any of those parts for future failures
Re: big block rocker shaft wear? [Re: idriveagremlin] #1541368
11/29/13 01:00 PM
11/29/13 01:00 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'd use 1.5 rockers for one thing and get better ones with new shafts.
Re: big block rocker shaft wear? [Re: idriveagremlin] #1541369
11/29/13 01:46 PM
11/29/13 01:46 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Just curious, What oil were you running with these rocker arms?
Since the PRW Rockers are not rollerized, you need oil that has a really high Zinc content. I had the same problem with a set of the iron Isky rocker arms. Kept galling the rocker shaft up. Finally went to a hardened shaft and changed over to Valvoline racing oil which is the highest Zink content you can get now.
Just a thought, but I would at least change the rocker shafts or you are going to experience the same thing again.
Good Luck
Old Geezer Racing
Re: big block rocker shaft wear? [Re: idriveagremlin] #1541370
11/29/13 02:01 PM
11/29/13 02:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My Harland-Sharp shafts looked way worse than that so I flipped em over a few years ago during my freshen up and never looked back but they oil the same either way from what I could tell..........
Re: big block rocker shaft wear? [Re: Thumperdart] #1541371
11/29/13 04:54 PM
11/29/13 04:54 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Am I not thinking straight here? Those shafts look like the oiling holes are in-line with the bolt holes (???). I think the shafts I have worked with have all had the oiling holes straight down when bolted up (not aligned with boltholes). This is why there is a right and wrong way to have them installed.
Re: big block rocker shaft wear? [Re: StealthWedge67] #1541372
11/29/13 06:00 PM
11/29/13 06:00 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I asked that question as well. If you look close, it appears there is a wear mark where the bolts go down thru down as well.
If those rockers he is using don't have bearings on them, then they aren't round because I would think there would be a wear pattern all the way across, not were it appears the bearings are riding, so I think the shafts aren't hard enough for those type of rockers.
But, never got an answer if both sides are the same or just the one side.
Re: big block rocker shaft wear? [Re: Dodgeguy101] #1541373
11/30/13 01:09 AM
11/30/13 01:09 AM
Dayton, OH
I
I
Dayton, OH
I have not taken the left side rockers off yet to check the other shaft.
What you are looking at is the bottom side that is bolted to the head.
I am using valvoline VR-1 racing oil. straight 40 weight. The rockers do have roller (needle) bearings in them. I do not know what oil was used before i got the car but the engine was assembled and used less than 500 miles before I got the car. probably has less than 2500 miles total now.
I changed the oil when I got the car and then after much prep of the chassis and suspension I went on drag week.
I have a new set of comp cams stainless roller rockers that are 1.5 ratio I guess I will put them on and check them soon after the install.
The car is a 1966 Belvedere 1 with a 4 speed.
Re: big block rocker shaft wear? [Re: idriveagremlin] #1541374
11/30/13 09:59 AM
11/30/13 09:59 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Your car? This is @ Gateway Motorsports Park during Drag Week.
Re: big block rocker shaft wear? [Re: Blues_Cuda] #1541375
11/30/13 10:08 AM
11/30/13 10:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That 52 Ford PU is my buddies that I rode with during
DW... nice ride.. it runs 11.50 on motor(no roll bar)
Re: big block rocker shaft wear? [Re: MR_P_BODY] #1541376
11/30/13 11:24 AM
11/30/13 11:24 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
the bearings are harder than your rocker shafts. ofcourse the shafts are going to wear. probably a bad heat treat on the rocker shaft. if the bearings are ok on the rockers, which they probably are. I would replace the shafts and move on.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: big block rocker shaft wear? [Re: Jerry] #1541377
11/30/13 03:03 PM
11/30/13 03:03 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I agree, not challenging.....any time you have a "focused" load, like small roller bearings with high valvespring pressure, the oiling requirments are of a thicker viscosity than a bushing that basically broadcasts its load but may have more drag. Good quality rocker shafts are what you need.
