Re: New main bearings in storeage. signs of skuffing in box
[Re: rustytoolss]
#1540021
11/26/13 11:16 AM
11/26/13 11:16 AM
RapidRobert
I would think mocking them up with a crank would show a wider contact area than bumping around in storage would. Plus bumping may raise a burr (if so polish it flat carefully being extremely conservative) whereas the crank would just make some shiny areas from where it polished the coating off & no sweat there. Check the backsides also since as you know the shells must fit flush
