First link is for the front door glass...the roof rail w/strips.Second link is for a hardtop...not for the 29 body type.
you need:
A29 Qtr Window GasketsOh yeah...my blurb is wrong...picture shows both sides and I need to double check where they are made...might be Thailand.
Also the leading edge of your qtr glass uses the same slide and w/strip package as the hardtop front door .Usually they are ok as they are pretty much fixed on the A29's and not sliding up and down like a hardtop front door glass.
