Re: Mopar Mechanical Service Near New Orleans Needed
[Re: duckblind]
#1539587
11/25/13 11:53 AM
11/25/13 11:53 AM
RapidRobert
What's going on with the brakes? The guys here can get to the bottom of it. Is it a rotor/hub fitment issue or something else in addition to that
[Re: duckblind]
#1539589
11/25/13 10:31 PM
11/25/13 10:31 PM
RapidRobert
Will they pump up (for a few seconds?) which as you know is air. I'm assuming you (bench) bled the M/C first. I would cap the M/C with brass inverted flare male fittings from the Edelman parts cabinet at your parts house. Then if the M/C is good & bled out the pedal will be rock hard with virtually no travel. If good then hookup the front brakes to the M/C port next to the firewall & work on bleeding them out. when you get that half bled (hard pedal) then hookup the rears & work on them. If it ain't air (they dont pump up) is it a general mushy feeling or not enough brake force being applied at the wheels or?
[Re: duckblind]
#1539591
11/26/13 12:48 PM
11/26/13 12:48 PM
RapidRobert
Alright bro , first thing I'd do is take care of the hub/rotor fit issue. those brass "Edelman" plugs are cheap & should be easy to come by. I'm thinking will they pump up (air) or are they just "mushy". On a tough case which this sounds like I would get the 2 fittings & cap the M/C & confirm its' integrity (& that it is bled out) & go from there. Holler how it turns out
[Re: duckblind]
#1539596
12/07/13 09:25 PM
12/07/13 09:25 PM
RapidRobert
I'd suggest capping both ports to confirm the pedal is rock hard with virtually no travel then if good hookup the rear brake line to the forward port on the M/C & if still good with a minimal amount of travel (some travel cuz you are activating half of the system) then hookup the front brake line to the M/C & start on the RF corner. Sometimes on a tough case pumping the pedal several times to agitate the air/fluid then the helper cracking the bleeder at just the right time on the 4th downstroke works to get the air out.
