pocket pal #1539513
11/25/13 12:12 AM
11/25/13 12:12 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Found the perfect spot for it.
Fastest 300
Re: pocket pal [Re: Crizila] #1539514
11/25/13 12:42 AM
11/25/13 12:42 AM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
better get some traction compound so as not to leave any "SKID" marks
SFI 25.5 depends,no leak,even at 213 mph....
Re: pocket pal [Re: Crizila] #1539515
11/25/13 01:02 AM
11/25/13 01:02 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
you can practice your hole shot
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: pocket pal [Re: WHITEDART] #1539516
11/25/13 01:07 AM
11/25/13 01:07 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
don't push your RT you will go red
Re: pocket pal [Re: WHITEDART] #1539517
11/25/13 01:14 AM
11/25/13 01:14 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Re: pocket pal [Re: Crizila] #1539518
11/25/13 10:29 AM
11/25/13 10:29 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
This could be a good excuse for crappy lights
"Just a Bracket car dressed up like a streetcar"
Re: pocket pal [Re: Just-a-dart] #1539519
11/25/13 11:19 AM
11/25/13 11:19 AM
Mi USA
Dyno Donnie Offline
Dyno Donnie  Offline
Mi USA
Is that product made by B&M performance.
Re: pocket pal [Re: Just-a-dart] #1539520
11/25/13 02:23 PM
11/25/13 02:23 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
I'll add it to my excuse list.
Fastest 300
Re: pocket pal [Re: Crizila] #1539521
11/28/13 03:29 PM
11/28/13 03:29 PM
dakotawilly Offline
dakotawilly  Offline
does it give you the option of #1 or #2 lane?
Re: pocket pal [Re: Crizila] #1539522
11/28/13 03:35 PM
11/28/13 03:35 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Something makes me wonder What happens if you find yourself cutting better lights on the crapper?
Do you redo your racecar interior to match your bathroom?
Might have some issues mounting belts on a Ferguson toilet.
Re: pocket pal [Re: MPerry] #1539523
11/28/13 03:36 PM
11/28/13 03:36 PM
dakotawilly Offline
dakotawilly  Offline
yes but if you have a bad day,you can just flush....
Re: pocket pal [Re: dakotawilly] #1539524
11/29/13 03:17 AM
11/29/13 03:17 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
At my age, "depends"
Fastest 300
Re: pocket pal [Re: Crizila] #1539525
12/04/13 01:14 AM
12/04/13 01:14 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
So does the sub belt come up thru the toilet seat or up the outside of the seat? Beep
Re: pocket pal [Re: Bigbeep] #1539526
12/04/13 01:47 AM
12/04/13 01:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure hope it comes around the front .. otherwise it
might get a bit wet.... now if you have bad light you
have the right to call it a sh1tty one
Re: pocket pal [Re: MR_P_BODY] #1539527
12/04/13 02:32 AM
12/04/13 02:32 AM
dakotawilly Offline
dakotawilly  Offline
yes,but,would the tank have to be vented outside,have a foam insert, and be certified? nhra would easily pass it,they always let a lot of crap through
