Emergency brake cable routing #1539495
11/24/13 11:53 PM
11/24/13 11:53 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
My brake cable is rubbing the body on the left hand side above the axle. It is the right hand cable.
Also rubbing on top of the sway bar.
Should it be under the sway bar?
Or do I need to readjust it?
Also the cable is rubbing on the right side of the body, but I think I need to loosen the clamp and move the cable to the left to take some of the slack out.
Is there only one clamp that hold that cable run where it goes from the left hand side to the right brake?
AAR cuda 71 rag challenger
Re: Emergency brake cable routing [Re: 3406pac] #1539496
11/25/13 12:57 PM
11/25/13 12:57 PM
Can you post a pic (or 2) of what's going on
Re: Emergency brake cable routing [Re: RapidRobert] #1539497
11/25/13 08:43 PM
11/25/13 08:43 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
The next few pictures might help.
One is the right side hitting the frame.
One is the clamp on the left side passing from left to right, not sure if that is supposed to be the only support or another one on the right side.
The other picture is where it rides above the sway bar, and rubs pretty heavy. Maybe should be under the sway bar.
Re: Emergency brake cable routing [Re: 3406pac] #1539498
11/25/13 08:44 PM
11/25/13 08:44 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Clamp
Re: Emergency brake cable routing [Re: 3406pac] #1539499
11/25/13 08:45 PM
11/25/13 08:45 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Rubbing sway bar
Re: Emergency brake cable routing [Re: 3406pac] #1539500
11/25/13 08:46 PM
11/25/13 08:46 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Rubbing frame
