How many trans could they build in a day?
#1539041
11/24/13 12:23 AM
11/24/13 12:23 AM
Posts: 105 Ontario, Canada
D149
Ontario, Canada
The numbers on my Cordoba's 727 are: PK3681865 5008 8407 Does that mean on April 14, 1975 it was the 8407th trans built? That is a lot of transmissions to build in a day! Just curious
1968 Valiant Signet 4dr. 273 4spd 1969 Road Runner 383 4spd 1969 Barracuda 318 auto 1970 Dart Swinger 340 4spd 1975 Cordoba 400-4bbl 1988 Caravelle 318 Auto 1999 Dakota R/T 2000 Viper GTS 2001 Ram 2500 Diesel 6spd 2018 Dodge Challenger GT (Winter beater!)
Re: How many trans could they build in a day?
[Re: RapidRobert]
#1539043
11/25/13 12:20 PM
11/25/13 12:20 PM
Posts: 528 SW CO
HemiSportFury
SW CO
I worked at the Kokomo Transmission Plant from 76-80. As I recall they were making around 3-4,000 per day. They made all the automatic transmissions for Chrysler as well as some or all for AMC and I think some for others.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: HemiSportFury]
#1539044
11/25/13 07:41 PM
11/25/13 07:41 PM
D149
Ontario, Canada
So I must be mistaken about what the last 4 numbers mean then. Anybody know what the 8407 means on my trans?
[Re: D149]
#1539045
11/25/13 07:54 PM
11/25/13 07:54 PM
RapidRobert
I'd think it'd be the date code for a specific year/month/day but if that is the case I'm not sure how you'd translate it unless it'd be 1978 for the (8), April for the (4), & the 7th day of the month (of April) for the (07)
[Re: D149]
#1539046
11/25/13 08:00 PM
11/25/13 08:00 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The last four digits are the sequence number, the number in a sequence of units built that day. Nothing coded, just a simple number that started with 0001 each day.
I can't testify to the max number built in a day but I've seen similar high numbers.
