Page 1 of 6 1 2 3 4 5 6
DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME #15383
05/22/05 09:04 PM
05/22/05 09:04 PM
Outside
thedriver Offline OP
Outside
i'm having problems starting my challenger. I take a new battery, throw it in the car start it....it runs fine until i shut it off, then it refuses to start again, i just end up suckin the juice out of the battery!!! i changed the ground cable and the pos. cable to the starter, jumped the car and it started fine, then i turned it off for 10 minutes (after a good 20 minute warm up) and it wont start again.. i'm charging the battery as we speak, but i dont feel i am solving the problem...HELP!!!
1973 challenger
Dana. 4 speed. Low deck.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: thedriver] #15384
05/22/05 09:15 PM
05/22/05 09:15 PM
Outside
Outside
i just tried the car again with the batt at full charge, and it spun fer about 10 seconds before it just went dead... this is frustrating
1973 challenger
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: thedriver] #15385
05/22/05 09:19 PM
05/22/05 09:19 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
defintion - won't start = won't start but turns over,
or
doesn't turn over?
check the relay
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: thedriver] #15386
05/22/05 11:47 PM
05/22/05 11:47 PM
Arlington, Texas
earlybee Offline
Happy Birthday earlybee  Offline
Arlington, Texas
my vote is to get the battery tested.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: earlybee] #15387
05/23/05 12:14 AM
05/23/05 12:14 AM
Chesapeake, Va
4aThrill Offline
4aThrill  Offline
Chesapeake, Va
hey make sure all of your accessories are off there could be an bad draw from one i had the same problem, my blower had an bad ground, charge the battery up and then turn everything off
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: thedriver] #15388
05/23/05 12:24 AM
05/23/05 12:24 AM
California
saccuda Offline
saccuda  Offline
California
have you had any other problems recently before this started happening? Long ago I had a problem similar to what you are describing that was caused by a failed ignition module.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: saccuda] #15389
05/23/05 09:01 AM
05/23/05 09:01 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
what does wont start mean? does it turn over and not run or does it not turn over. if it doesnt turn over, you probably have a bum battery
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: aarcuda] #15390
05/23/05 02:34 PM
05/23/05 02:34 PM
Outside
Outside
i have the battery charger out, this is the 3rd battt. i have tried in the car, all read full charge, yet, everytime i try to start the car, it simple feels like i dont have enuff juice to turn the car over...would 11.5:1 CR be a factor in this?? do i need a high powered starter or something?? i can spin the starter motor fer about 10 seconds until it starts to slow down and run outta juice, the car never used to have this problem...i did get it running last night fer about an hour....ran fine, but wouldn't start when i tried it again later on....if the alternator was pooched it would've died while running right?
1973 challenger
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: thedriver] #15391
05/23/05 02:39 PM
05/23/05 02:39 PM
amxautox Offline
amxautox  Offline
Check the grounds for corrosion including the starter to block. I've had a 13 1/2 to 1 engine and never had starter/cranking problems. Check the grounds and the starter.
Tom
author unknown
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: amxautox] #15392
05/23/05 02:49 PM
05/23/05 02:49 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If the alternator was dying, usually they will still put out enough juice to run the vehicle, but they won't charge the battery.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: DaytonaTurbo] #15393
05/24/05 03:19 PM
05/24/05 03:19 PM
Motor City
bluefish Offline
super street
bluefish  Offline
super street
Motor City
A battery should not die after only 10 sec of cranking
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: bluefish] #15394
05/24/05 03:54 PM
05/24/05 03:54 PM
New Jersey, US of A
PlumCrazy73Dodge Offline
New Jersey, US of A
BALLAST RESISTOR!!! Change that and she'll fire up. They go without you knowing and all it does is crank till she dies. Mike
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: PlumCrazy73Dodge] #15395
05/24/05 04:22 PM
05/24/05 04:22 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
then its your starter or the battery cables arnt making good contact.
take the big cables off and clean then termoinals and where they connect to on the battery posts, starter lug and engine block. if you have a new battery and clean terminals and it still wont crank for longer than 10 sec (although thats a LONG time to crank a starter), either the motor is REALLY REALLY tight, or the starter is going south.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: PlumCrazy73Dodge] #15396
05/24/05 04:35 PM
05/24/05 04:35 PM
New Jersey, US of A
New Jersey, US of A
woops, I thought it cranked over, but wasnt starting. Could be u need a high performance starter, I am not thqat good with the electronics.
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust
73 Cuda - Triple Black 340 4 speed
MIKE
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: PlumCrazy73Dodge] #15397
05/24/05 05:21 PM
05/24/05 05:21 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
if it was this changing batteries wont get it started
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 05dakota] #15398
05/24/05 05:40 PM
05/24/05 05:40 PM
Butler, PA
romanucci Offline
romanucci  Offline
Butler, PA
My vote is for the Starter.
There are many failure modes for starters, and I've experienced the one you are describing. I don't think you need a more powerful replacement, just one that cranks without seizing itself!
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME *DELETED* [Re: thedriver] #15399
05/24/05 10:34 PM
05/24/05 10:34 PM
Lorain, Ohio
MADMANMOPAR Offline
MADMANMOPAR  Offline
Lorain, Ohio
Post deleted by MADMANMOPAR
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: MADMANMOPAR] #15400
05/25/05 12:05 AM
05/25/05 12:05 AM
Sounds like the old toasted starter to me. Headers tend to get them. Go with the mini van starter. I run them on 15to1 engines with a crank trigger. Wish they had them in the 70s so we wouldn't have heard all the starter jokes.
BAYOU
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: MADMANMOPAR] #15401
05/25/05 12:30 AM
05/25/05 12:30 AM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
START YOUR CAR AGAIN (IF YOU CAN) AND WHILE IT IS RUNNING, PULL OFF THE POSITIVE BATTERY CABLE.. SEE IF IT STAYS RUNNING.. IF IT DIES RIGHT AWAY, SOMETHING IS WRONG IN YOUR CHARGING CIRCUIT.. BAD ALTENATOR, REGULATOR, SHORTED WIRE, BAD GROUND, ECT.. THAT IS DRAINING YOUR BATTERY..
do not do that!!!
An automobile is a DC system. When the battery is disconnected it will go into an open circuit and the voltage will sky rocket. This causes a high voltage spike and can instantly destroy any component in the vehicle with an integrated circuit!! It may not be immediate, but it will show up. This includes your radio, tach, ignition module, clock etc... anything with a little circuit board.
many have gotten away with it, but that dont make it right! Its old school diagnostics at best.
A cheap voltmeter will at least tell you if the alternator is trying to charge the battery to the regulators set point. Any voltage increase with the car running as opposed to not running will show the alternator's attempt to charge the battery. It doesnt mean it can though. To find out for sure you need to find out how many amps the alt is putting out. Then determine where those amps are going. If all is normal or acceptable, then you must check starter draw with an amp probe. If the starter draw is excessive, now you must determine the cause. Is the motor seizing? is the timing way too far advanced? are the starter bushings worn out?? is there a belt driven component seizing making it difficult to turn over?
and of course, your battery will need to be capable of suppling the required amps to crank this engine properly, and the cables will also need to be up to the task.
as you can see, this requires some proper equipment to diagnose properly, and may be better left to a true professional. It might save you some money.
Re: DODGE WONT START!! HELP!! TEY'RE ALL GONNA LAUGH AT ME [Re: 5537SG] #15402
05/25/05 01:32 PM
05/25/05 01:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I'm sorry but we've been disconecting batteries for a lot of years and never blew a curcuit or gauge doing it. The new cars suffer from those syptoms but the older cars don't. You just pull the cable and the car will imediately die if the charging system is bad. You are disconeced for less than a 1/2 a second.
