Re: dash "suede" paint ??
[Re: 71birdJ68]
#1538628
11/24/13 02:00 AM
11/24/13 02:00 AM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
Just a littler side note. On my dash the ash tray, and if I remember the glove door is a different shade than the rest of the dash. I guess cause they were painted separate. Remember, stuff wasn't perfect from the factory.
There is really no reason for those parts to be different shades? I definitely would not restore my dash and expect it to have different shades unless someone made a mistake. You need to paint all the pieces at the same time with the same paint? I'm glad my blue dash all looks the same shade or I'd have to pull it out and get it repainted!
[Re: RoadRunnerJD]
#1538635
11/24/13 01:58 PM
11/24/13 01:58 PM
Posts: 18,157 Mass
DAYCLONA
Mass
In an OEM application, blue was perhaps one of the most "mismatched" color shades when it came to "original" cars having a "uniform" color application...I do agree it looks nice when the dash components are of a uniform shade/hue, but in reality, the dashes, even in black, had variations in shade/sheen/hue/etc...esp E bodies, but it was apparent with all the Chrysler lines to varing degrees...
[Re: RoadRunnerJD]
#1538636
11/24/13 01:59 PM
11/24/13 01:59 PM
Posts: 12,160 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
When you look closely, there are differences in shading and texture on many of the individual components making up the dash and steering column. I would guess that Mopar had intended that the items all match, but different vendors or different batches of paint meant that the results were something different.
Now whether the OP wants to be "as delivered correct" or wants it to all match is up to him.
Master, again and still
[Re: DaveRS23]
#1538637
11/24/13 02:32 PM
11/24/13 02:32 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I disagree with Scott on this one, The paint that Mike sells IS the paint that was used.
Was used on what?
Keep in mind that I have 4 original paint duster dash assemblies in my stash, the paint I got from Mike doesn't match the original texture on any of them, Mikes had WAY too much texture (so much that it snags microfiber from a cloth when wiped). Keep in mind, it may not be the paint but rather the way it was applied, as I stated above, it could have been my application technique, but as mentioned I tried it twice and got the same results both times.
[Re: LimeliteAero]
#1538639
11/24/13 02:51 PM
11/24/13 02:51 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
How old is that original paint? 43 years old?
Yes, but all 4 of my originals look very similar to one another and short of some obvious exposed surfaces, there are many hidden out of reach areas that show zero wear. Those hidden areas don't look any different than the higher exposure areas other than some slight sun fading, as compared to the newly sprayed dash the texture on the 4 originals is much finer and even throughout regardless of exposure.
[Re: ScottSmith_Harms]
#1538640
11/24/13 03:03 PM
11/24/13 03:03 PM
Posts: 1,096 Waddell AZ
azblackhemi
Waddell AZ
http://www.instrument-specialties.com/products/
I tried theirs as well but the texture was way to strong as compared to my original samples. To be fair it might have been an application issue on my part but I did follow the directions to the letter......Twice.
I agree with Scott, when I use PPG's lacquer I have them leave out the suede additive because it is much too gritty with it. Without the suede it still has a little texture that seems just about right.
[Re: Commando1]
#1538648
11/24/13 04:11 PM
11/24/13 04:11 PM
Posts: 1,822 Colorado
denfireguy
Colorado
The best match I've seen, available in all interior colors.
$165.00 a PINT???
I paid $85 a pint for the same stuff from a local PPG supplier 3 years ago. It is not available at any price from the same place as they dumped lacquer. I wish I had bought more. They do still sell DDL thinner tho.
Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: 469runner]
#1538650
11/24/13 08:50 PM
11/24/13 08:50 PM
[Re: A12]
#1538657
11/25/13 02:33 PM
11/25/13 02:33 PM
Posts: 8,881 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
IMO the dash is "eggshell" not suede
The FSM calls it "suede" and the additive was also called the same back in the day. I have a 7 oz. spray bomb that I had made back in the early '80's and have never used it. Not sure if it'll even spray now and its probably not enough to do a full dash anyway but it'll be a good sample if I need it.
[Re: Stanton]
#1538658
11/25/13 06:39 PM
11/25/13 06:39 PM
Posts: 1,175 Woodbridge
Tommy The Chryco
Woodbridge
the suede paint is still available, suede was applied in a light mist. Most guys apply it to heavy, I do only because my clients drive there cars more frequently.
Fight the Good Fight- Elastomeric Bumpers and The Better "Shaker kits"
[Re: YYZ]
#1538661
11/25/13 09:56 PM
11/25/13 09:56 PM
Posts: 3,691 MO
cdp
MO
http://www.tcpglobal.com/restorationshop/I've had good luck and was happy with the outcome on my a12 with the Suade black I bought from TCP. not the greatest picture, but finished product less the cat hair.
[Re: FJR doc]
#1538664
11/26/13 01:23 AM
11/26/13 01:23 AM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
That looks awesome, FJR doc. And $65.00? Well done. Gonna write that one down in my little resto notebook, thanks for the tip.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1538665
11/26/13 03:07 PM
11/26/13 03:07 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
YUP!
That looks AWESOME! Nice job!
[Re: demon]
#1538668
11/26/13 11:18 PM
11/26/13 11:18 PM
Posts: 628 Mass
Mike Mancini
Mass
Hi Guys,
Just to clarify...The stuff we sell is the real deal. I bought out an old PPG jobber local to my town that had boxes and boxes of unopened bases,toners and additives dating from the 50's-70's. The paint shop closed in 1979, so nothing is newer than that.
We are very low on the additive, we have sold it to many many people over the last few years, but its about gone.
If you are getting too much gloss or too rough texture, it is most definately an application issue. If you use too much pressure it will make the additive stand up causing a rougher finish. If you spray it too wet and don't allow enough time between coats, it will gloss up. The key is light coats, low pressure to get the perfect suede "fuzzy" feeling.
Any original sample is not really a perfect reference due to the way lacquer breaks down and degrades simply with time, not to mention other outside forces.
Any questions, please call the shop. 401-267-0055
Thanks Mike
[Re: FJR doc]
#1538669
11/26/13 11:33 PM
11/26/13 11:33 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Is your dash black? If so, I tried various paints but eventually went with powder coating. I felt that the Tiger black matte fine texture was an exact match to my original dash frame. My local coater blasted and coated my frame, glove box door and ash tray door for $65. It looks sexy!
I too did powdercoating, dash, steering column, ash tray for less than $100, finish is perfect and way more durable than paint, I have no clue why people mess with a paint that is a crapshoot at best
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: MOPARMIKE69]
#1538672
11/27/13 10:57 AM
11/27/13 10:57 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
I also used Mikes stuff on the Daytona just recently and had good results. You can't spray it like you would outside panels for a good finish.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: Mike Mancini]
#1538673
11/27/13 12:00 PM
11/27/13 12:00 PM
Posts: 892 MA
steve70
MA
Hi Guys,
Thanks Mike
I was just at Mike's shop to drop off a gauge cluster for restoration and got to see a few complete dash's that were ready to be shipped out. The complete assemblies that I saw were absolutely beautiful and the texture looked perfect.
1970 Challenger T/A 4 speed
[Re: Mike Mancini]
#1538676
11/27/13 02:38 PM
11/27/13 02:38 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Hi Guys,
Thanks Mike
Thanks for posting Mike, as I said, it might have been an application technique issue and not your product. I still have leftover paint and a couple dashes to shoot, could you offer some tips on getting it right so I don't waste more material? Specific gun pressure, room temperature, spray distance, etc. that might help?
[Re: Stanton]
#1538678
11/27/13 03:30 PM
11/27/13 03:30 PM
AZ_A12_BEE
Dreaming of the 808
Get the paint wrong - easily strip it off and redo it. Get the powder wrong and its a whole different ballgame!
I my case and probably others as well, there is rust in the top corners which is not severe enough to cut out but enough to need a skim coat of bondo. This means powder is not an option as it won't adhere to the bondo. Also, doing an ashtray you only want the door done, not the tray itself. Unless you pop it apart and re-rivet it you're pretty much dinked there as well.
Not true in the ash tray, they just mask it off with special high temp tape.
My metal is perfect so powdercoating is the ticket, if my was rusty and had bondo I too would have had to use paint.
37 Plymouth PU
[Re: AZ_A12_BEE]
#1538679
11/27/13 03:44 PM
11/27/13 03:44 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
AZ A12 Bee I would love to see an up close side shot of your dash.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: 71birdJ68]
#1538687
11/27/13 09:41 PM
11/27/13 09:41 PM
Posts: 21,525 N.E. OHIO, USA
A12
N.E. OHIO, USA
Mind if I throw another little did bit, or maybe just let Mike comment on it. Seems like everybody wants a factory job, but we are all trying to do it perfectly. Maybe it should be done a little more hap hazard like they did at the factory, to get a more realistic look.
Not really IMO
[Re: 71birdJ68]
#1538689
11/27/13 10:47 PM
11/27/13 10:47 PM
A12
N.E. OHIO, USA
What a Richard Cranium. Keep the change.
Thanks But I have my opinion too and I just don't get why some think that ALL AMERICAN production line workers back then were either drunk, high or both and always did a $#!T quality job?? Why then do we try to make it as nice as we know it was when we took the part off to do a restoration? I see more runs and flaws on a car AFTER it was restored than before. Maybe the car you bought new back in '69 or '70 was built like a piece of cr@p and that's why you have YOUR opinion...mine wasn't. Thanks again for the comp.
[Re: A12]
#1538693
11/28/13 01:26 AM
11/28/13 01:26 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I painted mine with the correct Lacquer, I used my old school Binks #7 gun, and I still prefer to spray Lacquer..just hard to find.. Use quailty thinner, not the hardware store stuff, spray it on in thin but wet coats..3 coats should do it. It has been about 4 years, but I think I thinned it about 1 to 1 to get good results. The Binks 7 is more like a garden hose than current guns.. I also painted the steering column on a different day with the same paint.
[Re: sthemi]
#1538696
11/28/13 01:33 PM
11/28/13 01:33 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
That ol #7 was a Cadillac in its day! Mine is 31 years old and still looks and sprays like new!
[Re: sthemi]
#1538699
12/02/13 01:08 PM
12/02/13 01:08 PM
MOPARMIKE69
Nashville, TN
Here is an up close shot of my dash after using the original paint from Mike Mancini's. Shot at 50 on air pressure with a gravity feed gun. Buy the way I was able to shoot two dashes and steering columns and accessories with the one can of paint. I still have a little left in case of an emergency.
[Re: sixty9redgtx]
#1538703
12/04/13 03:22 PM
12/04/13 03:22 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok Mike, found the notes on how it was sprayed. Type gun-Sata Mini Jet hvlp Tip size-1.0 Pressure-28lbs 3 light coats (it was only coated enough for full coverage, not piled on thick at all) I have an idea Mike, why don't you do a spray out card for me that shows the desired result, send it out and I'll see how it matches up to my dash and see if I can match it with spray technique.
[Re: Stanton]
#2066356
05/03/16 03:34 AM
05/03/16 03:34 AM
Posts: 23 Canada
CdnValiant
Canada
I'm in BC. Thanks for all the replys!
