1969 Coronet R/T - NO LIGHTS!! #1538496
11/22/13 07:38 PM
11/22/13 07:38 PM
Wisconsin
wkroncke17 Offline OP
Wisconsin
All,
Once again, the car is put together and running, but I have no lights...the fuses are ok, I'm not good with wiring at all....
Has anyone had this happen after painting and putting the car back together?
Re: 1969 Coronet R/T - NO LIGHTS!! [Re: wkroncke17] #1538497
11/22/13 07:42 PM
11/22/13 07:42 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Check your headlight grounds, fresh paint is a good insulator.
jess
Yeah, it's hopped up to over 160...
Re: 1969 Coronet R/T - NO LIGHTS!! [Re: wkroncke17] #1538498
11/22/13 08:17 PM
11/22/13 08:17 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Switch or ground!
Do you have dash lights?
Re: 1969 Coronet R/T - NO LIGHTS!! [Re: wkroncke17] #1538499
11/22/13 08:39 PM
11/22/13 08:39 PM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
Bulkhead connector may have issues. Turn them on and then apply pressure to the plug on engine side or twist some. You can also undo the forward light harness there and check for Voltage....
Good Luck.
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger Rallye wanna be RT
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1991.5 W250 Cummins- Big Chief
Re: 1969 Coronet R/T - NO LIGHTS!! [Re: wkroncke17] #1538500
11/23/13 12:03 AM
11/23/13 12:03 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Don't forget to look at the dimmer switch on the floor........
Troy
Houston Mopar Connection Club
Re: 1969 Coronet R/T - NO LIGHTS!! [Re: moparpollack] #1538501
11/23/13 01:04 PM
11/23/13 01:04 PM
Wisconsin
Wisconsin
Switch or ground!
I do have dash lights!
Re: 1969 Coronet R/T - NO LIGHTS!! [Re: hemi68charger] #1538502
11/23/13 01:08 PM
11/23/13 01:08 PM
Wisconsin
Wisconsin
To make sure it didn't come disconnected?
I didn't take that out.
Re: 1969 Coronet R/T - NO LIGHTS!! [Re: jt4406] #1538503
11/23/13 01:11 PM
11/23/13 01:11 PM
Wisconsin
Wisconsin
jess
Jess, please forgive my ignorance of wiring/electrical, but where are the headlight grounds?
Thanks!
Wally
Re: 1969 Coronet R/T - NO LIGHTS!! [Re: wkroncke17] #1538504
11/23/13 03:26 PM
11/23/13 03:26 PM
85086
Lil Herman
Lil Herman
85086
jess
Thanks!
Wally
Look along the top of the radiator support for screw holes. The ground wire is on headlight harness.
Re: 1969 Coronet R/T - NO LIGHTS!! [Re: moparpollack] #1538505
11/23/13 03:45 PM
11/23/13 03:45 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
John is right, go to the back of your headlites, follow the wires off them, one will go to a ground screw, but may go into the harness first, follow along it til you find it. Be aware of you connectors for any wires that may have broken off close to a pigtail.
jess
Re: 1969 Coronet R/T - NO LIGHTS!! [Re: wkroncke17] #1538506
11/23/13 04:18 PM
11/23/13 04:18 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Most likely a bad ground under the paint...
EZ to troubleshoot...
Make a long wire lead of 14 guage or higher...
1. Ground 1 end to the chassis or battery -
2. Turn the headlites ON
3. Ground the wire lead to the headlite housing
What happens?
A. If the headlites turn ON, then you have a bad ground
B. If the headlites don't turn ON, then you have no 12V+ going to the headlites, need to recheck wiring harness, bulkhead connectors, headlite switch and lo/hi beam switch
Just my $0.05...
