1969 Coronet R/T - NO LIGHTS!!
#1538496
11/22/13 07:38 PM
11/22/13 07:38 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
Re: 1969 Coronet R/T - NO LIGHTS!!
[Re: wkroncke17]
#1538497
11/22/13 07:42 PM
11/22/13 07:42 PM
Posts: 1,567 Ky
jt4406
Ky
Check your headlight grounds, fresh paint is a good insulator. jess
Yeah, it's hopped up to over 160...
[Re: wkroncke17]
#1538498
11/22/13 08:17 PM
11/22/13 08:17 PM
moparpollack
Lil Herman
Lil Herman
85086
Switch or ground! Do you have dash lights?
[Re: wkroncke17]
#1538499
11/22/13 08:39 PM
11/22/13 08:39 PM
Posts: 1,548 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Bulkhead connector may have issues. Turn them on and then apply pressure to the plug on engine side or twist some. You can also undo the forward light harness there and check for Voltage....
Good Luck.
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger w 383 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1997 Ram B3500 Van 5.9 1991.5 W250 Cummins- Big Chief
[Re: wkroncke17]
#1538500
11/23/13 12:03 AM
11/23/13 12:03 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Don't forget to look at the dimmer switch on the floor........
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: moparpollack]
#1538501
11/23/13 01:04 PM
11/23/13 01:04 PM
wkroncke17
Wisconsin
Switch or ground!
I do have dash lights!
[Re: hemi68charger]
#1538502
11/23/13 01:08 PM
11/23/13 01:08 PM
wkroncke17
Wisconsin
To make sure it didn't come disconnected? I didn't take that out.
[Re: jt4406]
#1538503
11/23/13 01:11 PM
11/23/13 01:11 PM
wkroncke17
Wisconsin
Jess, please forgive my ignorance of wiring/electrical, but where are the headlight grounds? Thanks! Wally
[Re: wkroncke17]
#1538504
11/23/13 03:26 PM
11/23/13 03:26 PM
moparpollack
Lil Herman
Lil Herman
85086
Look along the top of the radiator support for screw holes. The ground wire is on headlight harness.
[Re: wkroncke17]
#1538506
11/23/13 04:18 PM
11/23/13 04:18 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Most likely a bad ground under the paint... EZ to troubleshoot... Make a long wire lead of 14 guage or higher... 1. Ground 1 end to the chassis or battery - 2. Turn the headlites ON 3. Ground the wire lead to the headlite housing What happens? A. If the headlites turn ON, then you have a bad ground B. If the headlites don't turn ON, then you have no 12V+ going to the headlites, need to recheck wiring harness, bulkhead connectors, headlite switch and lo/hi beam switch Just my $0.05...
