71 Barracuda Convertible Power Top Relay #1538280
11/22/13 03:41 PM
11/22/13 03:41 PM
Postville, IA
CudaDave7071 Offline OP
Postville, IA
I'm converting from manual to power top.
Is there anyone making the power top relay? Any parts interchange?
Re: 71 Barracuda Convertible Power Top Relay [Re: CudaDave7071] #1538281
11/22/13 08:14 PM
11/22/13 08:14 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I wasn't aware that there was one. The older convertibles did not have a relay. The later convertibles use two relays, which is what I used along with the switch in my son's Dart since we didn't have the correct switch and I wanted to put it in the console anyway.
Re: 71 Barracuda Convertible Power Top Relay [Re: CudaDave7071] #1538282
11/23/13 01:44 AM
11/23/13 01:44 AM
Andrewh Offline
Andrewh  Offline
the pumps are pretty much the same into the 90's lebaron.
the old ones orginally only had a circuit breaker under the drivers kick pannel.
power came directly from the amp meter.
I took that circuit out and ran a new larger power line to a distribution block behind the seat and wired up 2 relays(well 3, one for a fuel pump) and used the original wires to send signals to the relay's.
you can even get the trailer plug kit from pep boys and plug it in directly so you don't have to cut either end of the pump.
Re: 71 Barracuda Convertible Power Top Relay [Re: Andrewh] #1538283
11/23/13 01:49 AM
11/23/13 01:49 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I used the entire wiring harness from a LeBaron that we parted out. I've got the same setup for my Barracuda. It just makes it easier that way...
