Anyone have an OOB 72cc std-port Victor I can borrow? #1538148
11/22/13 11:13 AM
11/22/13 11:13 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Yeah, it's an odd request, but here's why. I'd like to inspect a 2012-revision standard-port 72cc Edelbrock Victor to do some comparisons between the later version and the earlier OOB 75cc version I have on hand.
The newer 72cc version is down on flow compared to the original style and I'm curious what I can determine are the differences besides the obvious changes to the combustion chamber.
I don't need to do any mods, just want to perform some basic port & chamber comparisons & measurements, plus possibly run a couple of flow tests on it.
Yes, I could order one from Jeg's or Summit, do my comparisons, then return it since it will still be OOB after I give it the . But I figured I'd post this first, in case there was someone sitting on a head that I could use w/o going through the buy & return process.
Thanks,
Brad
Re: Anyone have an OOB 72cc std-port Victor I can borrow? [Re: BradH] #1538149
11/24/13 05:21 PM
11/24/13 05:21 PM
BradH Offline OP
BradH  Offline OP
Long shot as it may be, I'll give it a
Re: Anyone have an OOB 72cc std-port Victor I can borrow? [Re: BradH] #1538150
11/24/13 05:44 PM
11/24/13 05:44 PM
SoCal
Brian Hafliger Offline
SoCal
Why didn't you just ask me? I can tell you the bowl is tiny compared to the early version.
Brian Hafliger
Re: Anyone have an OOB 72cc std-port Victor I can borrow? [Re: Brian Hafliger] #1538151
11/25/13 12:18 PM
11/25/13 12:18 PM
BradH Offline OP
BradH  Offline OP
Oh, OK!
In that case, I have another question: Is the chamber any different between the old and new versions in any way OTHER than the quench area being pulled in closer to the valve seats? I can't tell just from pictures if Edelbrock filled in the plug side anywhere that might also be contributing to the loss in out-of-the-box flow.
Thanks,
Brad
