automatic transmission question #1537806
11/21/13 06:07 PM
11/21/13 06:07 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Hey fellas, got an A904 in my 73 Dart Sport 340. Planning to rebuild it in a week or so, but, it has an issue that is a bit odd to me.
I top it off with fluid, drive it and all is fine. If I let it sit over night, no problem. However, if it sits for 24 hours or more, it leaks about 2 quarts onto the floor.
My guess is that the converter is draining back down to the input shaft and thats where the trans fluid is coming from. but, if thats what it is, how do I stop it?
Next question, Im ordering the parts to rebuild it. Anyone have any input on what converter and what trans kit to order. I dont plan to run a high stall converter or anything since its just a mild cruiser.
Laine.
Re: automatic transmission question [Re: Lmopar69] #1537807
11/21/13 06:16 PM
11/21/13 06:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Drainback is normal the leak is not. Fix the leak which is probably the dipstick tube seal. If you lose 2 qts I think you are over filling it to begin with. Are you checking it running in neutral.
Re: automatic transmission question [Re: Lmopar69] #1537808
11/21/13 06:20 PM
11/21/13 06:20 PM
clean it off with the car wash wand then the next day see specifically where it is leaking from. Sprinkling talcum power on it can help pinpoint a leak as they can be deceptive. I think there's 4 or 5 locations where it could be leaking from but not from the input shaft (front pump seal) when it ain't running since the fluid level ain't that high. Transgo TF1 shift kit & Transgo used to offer a converter that was a bit more tight than stock (more efficient) for a daily driver & no doubt converter tech has improved in 40 yrs if a tighter converter is what you are after. (it does have a 340 but you did say mild cruising )
Re: automatic transmission question [Re: RapidRobert] #1537809
11/21/13 06:29 PM
11/21/13 06:29 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Also if you use a Transgo shift improver kit, they are supplied with a new manual valve which eliminates drainback.
Re: automatic transmission question [Re: teflon] #1537810
11/21/13 07:06 PM
11/21/13 07:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It does ???? I never heard that before
Re: automatic transmission question [Re: JohnRR] #1537811
11/21/13 08:03 PM
11/21/13 08:03 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
When they leak like that it can also be the shift shaft seal.
2 quarts is a ton of trans oil. It must look like they beached the Exxon Valdez at your place.
Re: automatic transmission question [Re: teflon] #1537812
11/21/13 08:04 PM
11/21/13 08:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nothing can eliminate converter drainback, the Transgo valve merely allows the converter to recharge in Park.
Re: automatic transmission question [Re: teflon] #1537813
11/21/13 08:04 PM
11/21/13 08:04 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
I think you may have the modified manual valve supplied with the Transgo kits confused. That valve allows the convertor to fill in the park position as well as neutral. Sonnax offers a similar manual valve to do the same thing as well as a new pressure regulator valve that fills the convertor better at low engine speeds.
Re: automatic transmission question [Re: PC-CHARGER] #1537814
11/21/13 08:45 PM
11/21/13 08:45 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I 2nd
Re: automatic transmission question [Re: 500ciDuster] #1537815
11/22/13 11:21 AM
11/22/13 11:21 AM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
I wiped it down and put the car up on stands for the next couple weeks while Im out of town. When I get back, I should be able to pin point the offending seal/gasket.
And to answer, yes, I checked the level and filled it properly.
I'll be rebuilding the 904 I have sitting in the shop and replacing the trans in the car, so the leak may be a moot point anyway.
Laine.
Re: automatic transmission question [Re: 500ciDuster] #1537816
11/22/13 12:05 PM
11/22/13 12:05 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
I 2nd
I 3rd
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: automatic transmission question [Re: Lmopar69] #1537817
11/22/13 12:22 PM
11/22/13 12:22 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Laine.
I wouldn't even bother with it. Swap the trans then do a complete rebuild on this one and you have a good spare.
I have mechanical Aptitude.
I can screw up anything.
Re: automatic transmission question [Re: bboogieart] #1537818
11/22/13 02:03 PM
11/22/13 02:03 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Either way, end result is I can drive the thing from Alabama to Nebraska (moving). Saves me at least one trip with the trailer.
Its pretty cool having a "collection" of Mopars, until you have to move 1100 miles. Becomes quite a logistical nightmare at times.
Laine.
