What to get for igniton system? #153618
11/19/08 10:09 PM
11/19/08 10:09 PM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
Hey everyone, I'm looking to buy an ignition system for my car. I'm doing a complete restification and have already built the motor but don't have anything to work with for acessories so I need to buy everything. I definitly want electronic ignition, the motor is a mild 440, .040" over, mild hydraulic cam, aluminum heads, dual plane intake, nothing crazy. It will be a street strip car with plenty of strip time. I was wondering if I should buy the conversion kit for my current distributor or buy a completely new one. Also, should I get a MSD box , and if so, which one is the best for what I need. I'd like to have a rev limiter but being an auto car, I don't know how much that'll be needed really. I need to start looking at pricing as I now have more of a budget to follow and no more "money is no object" scenario. Let me know what combo's work for you. Thanks in advance!
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: What to get for igniton system? [Re: itali83] #153619
11/19/08 11:27 PM
11/19/08 11:27 PM
I would consider FBO coil/ecu.
Re: What to get for igniton system? [Re: RapidRobert] #153620
11/21/08 12:40 PM
11/21/08 12:40 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
to me... Mopar performance ignition is good enough and still a Mopar
Re: What to get for igniton system? [Re: itali83] #153621
11/21/08 01:23 PM
11/21/08 01:23 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I have a Pertronix distributor on the 440 in my Coronet and it works great. I checked the advance curve and it was already set up for a 440 per Ebergs article in Mopar Action. You don't need the MSD with this dist, it has the proven Pertronix module in it. I also have the 60,000 volt Pertronix "Flame Thrower" coil. The engine starts quickly with the setup. It is a vacuum advance dist. My fuel economy went up dramatically after hooking up the vacuum canister. Highly recommended for a street motor imo...
Re: What to get for igniton system? [Re: NachoRT74] #153622
11/21/08 01:24 PM
11/21/08 01:24 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
I got the MSD 6al thats black with a MP logo on it. You can run them off a stock elec distributor or points distributor, and it totally deletes that pesky ballast resistor.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: What to get for igniton system? [Re: 70dart360] #153623
11/21/08 10:55 PM
11/21/08 10:55 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Petronix is great. Have used several.
Be sure to use their coil or one that has the same specs and you should be gold.
Re: What to get for igniton system? [Re: SomeCarGuy] #153624
11/22/08 12:33 AM
11/22/08 12:33 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The MP setup will work fine. I would price the FBO setup also as it works very good. You dont really need MSD for what you are building but of course if you want to spend the money it to will work good. As you know I run mid 11's with the MP orange ECU and the old Acell Super coil and it works great as I shift at 6200 and it never misses a beat. Ron
Re: What to get for igniton system? [Re: itali83] #153625
11/22/08 09:40 AM
11/22/08 09:40 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I like MSD 6AL for a few reasons,works great with Mopar distributor,rev limiter,and reliable.Oh and one more,if it ever does fail just send it back to MSD and it will be better than new for around $30.00.
Gus
64 Plymouth Savoy
Dana 60
Re: What to get for igniton system? [Re: Lefty] #153626
11/22/08 01:28 PM
11/22/08 01:28 PM
ILL
Greentween Offline
Greentween  Offline
ILL
I dont recommend the Pertronix. I had bad results with it. I did back to back to back tests comparing the pertronix dizzy with my FBO dizzy and FBO box. With the pertronix the car would not idle correctly. Same timing both dizzys, no answer from pertronix as to why, although they did recommend different things to try (coil, direct 12v power feed, ect). Pop the FBO one back in and use its box, and car would idle perfect.
Plus the Pertronix you will need to grind on the head for it to fit (stock head).
Re: What to get for igniton system? [Re: Greentween] #153627
11/22/08 03:52 PM
11/22/08 03:52 PM
SomeCarGuy Offline
SomeCarGuy  Offline
Just put the Petronix kit in an old dizzy.
Re: What to get for igniton system? [Re: SomeCarGuy] #153628
11/22/08 05:09 PM
11/22/08 05:09 PM
5thAve Offline
5thAve  Offline
Im happy with the mopar performance distributor and normal ECU I have on my 360. You can always get a better ignition box later if you want something different.
Re: What to get for igniton system? [Re: Greentween] #153629
11/22/08 05:52 PM
11/22/08 05:52 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
it needs a 12v feed, not thru the ballast resistor.
Re: What to get for igniton system? [Re: RapidRobert] #153630
11/22/08 07:11 PM
11/22/08 07:11 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I would pony up for a MSD. The 6AL should be fine,,,,i have that in the Charger (street car),,,,and have a Digital 6Plus in the Belvedere (race car)
I have run the MP orange,,and chrome,,,,and also did the FBO system...
I like the MSD by far...
Much easier on starting,,,built in rev limiter,,,car ran ALOT better..........
I "hid" mine under the dash/glove box,,,and ran the wires thru the firewall....very clean looking.......
I had nothing but problems with the FBO stuff,,,kept burning ballast resisters,,,and then a ECU box....
Re: What to get for igniton system? [Re: 05dakota] #153631
11/22/08 07:29 PM
11/22/08 07:29 PM
ILL
Greentween Offline
Greentween  Offline
ILL
Yep did that, 12v direct from battery. Unstable Idle.
Re: What to get for igniton system? [Re: Greentween] #153632
11/22/08 08:02 PM
11/22/08 08:02 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
http://www.msdignition.com/Products/Dist...istributor.aspx
MSD ready to run pro distributor. Simple clean install with only 3 wires to hook up. No external msd ignition box is needed. However it doesn't have the multi-spark or rev limiter of the MSD boxes. If you really want a msd box, go with a 6AL, hook it up to a MP adjustable distributor. My preference would be to just go with the MSD all-in-one dist for simplicity's sake. Also I've heard enough stories of MSD box failures leaving people stranded.
Re: What to get for igniton system? [Re: 69CHARGERMD] #153633
11/22/08 09:42 PM
11/22/08 09:42 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Same here.
Went thru 2 ballasts, then the FBO ECU failed, replaced with a MP chrome ECU, 1 more ballast then the MP ECU failed. All this within 1000 miles. I think it was the FBO coil causing the failures
Went back to a MP chrome, cheap Accel SS coil, 1.25 ohm ballast, 15,000 miles without a let down.
The MP chrome box is more than enough for most street cars (stay away from the MP orange box). If you want more, I'd go with a Mallory Hy-Fire 6al before the MSD 6al. You'll get more features for less $.
Re: What to get for igniton system? [Re: B5 Bee] #153634
11/22/08 09:51 PM
11/22/08 09:51 PM
Alright & is Mallory still made in USA.
Re: What to get for igniton system? [Re: RapidRobert] #153635
11/22/08 10:47 PM
11/22/08 10:47 PM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
Thanks everyone for your input. What is this FBO set up some are talking about. I'm really looking at keeping it simple and getting the mopar performance electronic conversion kit. Distributor, wire harness, box, ballast all in one. I can always add an ignition box at a later time if needed but I really want to get this car together before gas is illegal or 50 bucks a gallon so I need to simplify things where I can. Thanks again.
Re: What to get for igniton system? [Re: itali83] #153636
11/23/08 12:50 PM
11/23/08 12:50 PM
ILL
Greentween Offline
Greentween  Offline
ILL
Its fatory stuff. He sets up your dizzy to your combination, and supplies a factory type box, coil, ballast.
http://www.4secondsflat.com/
Re: What to get for igniton system? [Re: Greentween] #153637
11/23/08 01:29 PM
11/23/08 01:29 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Deep pockets? go MSD
Best bang for the buck. MP. Their new distributors are made by Mallory and have adjustable advance curves.
