My 69 Super Bee has a 3" leaf spring inboard kit.
Before I bolt the rear suspension together, I was just checking the trust angle.
Plumb bobbed the front of the leaf spring mounting holes to the garage floor.
Chalked it across. Found the center.
Chalked another line perpendicular to the axle centerline to the front of the car.
Plumb bobbed the front K member mounting bolts to the garage floor. The center of that line was 1/4" off the line perpendicular of the axle.
Is this a little or alot? What's that is degrees?
