ok a- body guys #1534522
11/17/13 09:14 PM
11/17/13 09:14 PM
ky
headhunter Offline OP
ky
how do you cool your big block or hemi a- body cars I have a becool radiator for now but can not fit a electric fan in front of the water pump pulley
Re: ok a- body guys [Re: headhunter] #1534523
11/17/13 09:25 PM
11/17/13 09:25 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
cut core support move radiator fwd.
Re: ok a- body guys [Re: Randy..] #1534524
11/17/13 09:28 PM
11/17/13 09:28 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Use it as a pusher and put the fan in front of the radiator???
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: ok a- body guys [Re: slippery440] #1534525
11/17/13 09:30 PM
11/17/13 09:30 PM
ky
ky
isn't it harder to cool a car with a pusher type fan?
Re: ok a- body guys [Re: headhunter] #1534526
11/17/13 09:37 PM
11/17/13 09:37 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
I had the same problem. I used 2 smaller fans that are mounted diagonally. Cools ok, but would be better if I mounted them on a shroud.
Randy
Re: ok a- body guys [Re: headhunter] #1534527
11/17/13 09:43 PM
11/17/13 09:43 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Same fan just reverse the wires. Your still pushing or pulling the same air flow.
Re: ok a- body guys [Re: slippery440] #1534528
11/17/13 11:06 PM
11/17/13 11:06 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I have a griffin rad with a I think 18" fan as a puller ! Rad is in the standard location ! It's real tight and getting the rad out is a pita but it fits ! I run an electric water pump though ?
Re: ok a- body guys [Re: 70dusterjohn] #1534529
11/17/13 11:16 PM
11/17/13 11:16 PM
ky
ky
ive been thinking about a electric pump just want to keep it cool all the time what fan are you using I tried a hhr fan its to thick even
Re: ok a- body guys [Re: headhunter] #1534530
11/17/13 11:41 PM
11/17/13 11:41 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I've got a pusher on my barracuda, doesn't over heat. and yes it doesn't work as well but it does work.
Re: ok a- body guys [Re: headhunter] #1534531
11/17/13 11:43 PM
11/17/13 11:43 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
on my dart i am using a summit 27.5x19 aluminum rad, a ford 3.8 tours(spelling) electric fan and a summit electric water pump, which is really a CVR brand water pump. so far it has kept my mid ten second big block dart cool. i hope to drive this car on the street next year.my radiator core support has not been changed but that does sound like a good ideal for me room.here is a pic of my set up. thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: ok a- body guys [Re: headhunter] #1534532
11/17/13 11:46 PM
11/17/13 11:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Elec. water pump and HHR elec. fan tight but works great..........move the radiator as stated and you should be fine.
Re: ok a- body guys [Re: headhunter] #1534533
11/17/13 11:56 PM
11/17/13 11:56 PM
Deerfield, Ohio
Deerfield, Ohio
ive been thinking about a electric pump just want to keep it cool all the time what fan are you using I tried a hhr fan its to thick even [/quot
I think it's a derale (sp) ? 18" it's pretty thick !
Re: ok a- body guys [Re: 70dusterjohn] #1534534
11/18/13 01:10 AM
11/18/13 01:10 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I have an 18" pusher on my aluminum rad. Works fine.
Re: ok a- body guys [Re: 70dusterjohn] #1534535
11/18/13 01:14 AM
11/18/13 01:14 AM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I was dealing with the same issue. Still not able to keep it cool all the time but very manageable. I am thinking about throwing a t stat in it to see if slowing the water flow a bit cools it a little better.
https://board.moparts.org/ubbthreads/show...rue#Post7829463
Re: ok a- body guys [Re: Thumperdart] #1534536
11/18/13 01:31 AM
11/18/13 01:31 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
By HHR do you mean the Chevrolet HHR?
Re: ok a- body guys [Re: 451Cuda] #1534537
11/18/13 01:36 AM
11/18/13 01:36 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yes sir...............
Re: ok a- body guys [Re: mopar65] #1534538
11/18/13 02:02 AM
11/18/13 02:02 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
What hoses are those? I need to get some for my '68 Barracuda. Thanks, Steve
Re: ok a- body guys [Re: Thumperdart] #1534539
11/18/13 02:18 AM
11/18/13 02:18 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
That cools a big block on the street? If so I'm definitely getting one...do I want a genuine GM part, or will aftermarket replacement work just as well?
Re: ok a- body guys [Re: 451Cuda] #1534540
11/18/13 08:08 AM
11/18/13 08:08 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I set mine into the core support. 32" X 19" Griffin rad with chevy hhr fan.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: ok a- body guys [Re: deaks] #1534541
11/18/13 08:19 AM
11/18/13 08:19 AM
gregsdart Offline
gregsdart  Offline
How much more room do you need to do exactly what you want? If it is a real small amount, you might be able to set the motor back enough to get there without anything more than slotting a hole or two. Plus you just shifted 800 lbs back a touch. The other thing that comes to mind is build, or use a very good sealing shroud. any leakage around the edges takes away from the system efficiency.
