choosing correct size slick
#1534360
11/17/13 01:45 PM
11/17/13 01:45 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
68 dart stroked 440 1150 holley,680 roller 12.5 flat top,8' 5500 stall had brand new 8 3/4 4.11 spool axles etc. 29 x9 hoosiers. 60fts. have been terrible 1.49's put new qa1 shocks in. best times 10.07@134mph 60 ft.1.44 had ladder bars adjusted by profesional,next time out blew the rear apart. (ring n pinion) putting dana in. how wide of slick should i use?
Hell Hath No Fury Like Mine
Re: choosing correct size slick
[Re: sixpacksteve]
#1534361
11/17/13 04:23 PM
11/17/13 04:23 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
68 dart stroked 440 1150 holley,680 roller 12.5 flat top,8' 5500 stall had brand new 8 3/4 4.11 spool axles etc. 29 x9 hoosiers. 60fts. have been terrible 1.49's put new qa1 shocks in. best times [Email]10.07@134mph[/Email] 60 ft.1.44 had ladder bars adjusted by profesional,next time out blew the rear apart. (ring n pinion) putting dana in. how wide of slick should i use?
As wide as you can fit in the wheelwell.
[Re: B G Racing]
#1534362
11/17/13 04:35 PM
11/17/13 04:35 PM
dartman366
Mt. Vernon, Ohio
I redid my back half last winter and went from a 29.5 X11.5 phoenix to a 14.0X31 goodyear and car has never hooked this consistant, I also set the rear up so I can go to a 14X32W if the need ever arises.
[Re: dartman366]
#1534363
11/17/13 05:33 PM
11/17/13 05:33 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
really! car is mini tubbed, i'm going to radius the quarters, so 14's is Not too much?
[Re: dartman366]
#1534366
11/17/13 08:17 PM
11/17/13 08:17 PM
Posts: 9,999 Frostbitefalls MN (Rocky&Bullw...
gregsdart
"60 ft.1.44 had ladder bars adjusted by profesional,next time out blew the rear apart." I think your helper was on to something! The fastest will be the lightest and narrow, but inconsistent. They may only be fastest on a very well prepped track. Big is best for consistancy, so if you want to win bracket events, go as big as you can.
[Re: BADDART]
#1534373
12/01/13 10:48 AM
12/01/13 10:48 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i'm in the process of modifying a dana 60 was going with 4.10's going to see if a 30" or 31"will fit in wheel well, if so i'll go w/4.30's
[Re: sixpacksteve]
#1534374
12/01/13 11:41 AM
12/01/13 11:41 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If bracket racing, the biggest and widest you can fit in it... if its a heads up type then its a balancing act to what size... wide tires are a drag going down the track
[Re: MR_P_BODY]
#1534375
12/02/13 09:26 PM
12/02/13 09:26 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i'm thinking 11.5 wide. how wide when its starts to hold me back?
[Re: sixpacksteve]
#1534376
12/02/13 10:16 PM
12/02/13 10:16 PM
MR_P_BODY
Tires alone are a drag... but you have to have them... look at the fronts we run.. tall skinny ones.. I would say after about 10" wide they become a larger drag BUT is that enough to hook on any track
[Re: MR_P_BODY]
#1534377
12/03/13 09:50 PM
12/03/13 09:50 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
last time out, went 3- 10.0's reset the ladder bars correctly and blew the new 8 3/4 rear. i know i'll see the 9's once the new dana is in. best, 60 ft. so far 1.44
[Re: sixpacksteve]
#1534378
12/03/13 10:36 PM
12/03/13 10:36 PM
Posts: 526 NC
barracuda man
NC
Ya you'll need the dana for sure.I have a mini tub 67 cuda and have a MT 29.5x10.5W. Biggest tire i can fit under it.
[Re: barracuda man]
#1534379
12/05/13 07:31 PM
12/05/13 07:31 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
how fast are you going? and do you get wheel spin?
