Unknown 440 #1534284
11/17/13 10:01 AM
11/17/13 10:01 AM
Oklahoma
lenogris Offline OP
lenogris  Offline OP
Oklahoma
So i have bought a 66 coronet with a 440 it looks to be an ex drag car that someone was trying to make a street car. My question is i know nothing about the engine or whats been done and i would like to know if there is anyway for me to eyeball some stuff and see? I know for sure it has a holley 750cfm it has a torker 440 intake and i just put a new melling HP oil pump.
Re: Unknown 440 [Re: lenogris] #1534285
11/17/13 10:26 AM
11/17/13 10:26 AM
Andrews,In. U.S.of A.
67_Satellite Offline
You could either take the sellers word,or disassemble and measure things.You can check the cam lift &duration with a degree wheel,visually look for part numbers(heads,cam,etc.)and compare them against what the seller stated.When it comes to stuff like pistons you'll have to dig deeper for the answers.If the guy seemed honest about the parts, and you can verify what he claimed, you could probably belive the rest on faith from there.
Re: Unknown 440 [Re: 67_Satellite] #1534286
11/17/13 10:36 AM
11/17/13 10:36 AM
Oklahoma
lenogris Offline OP
lenogris  Offline OP
Oklahoma
lucky me he did not know anything. Best i could say is that the cam is a purple shaft. I dont have the tools to go to far right now, though i will next month. I have been told just to let it be and race the car until something breaks then go ahead with the figuring out then.
Re: Unknown 440 [Re: lenogris] #1534287
11/17/13 10:38 AM
11/17/13 10:38 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
drive it.check plugs.take it to the track
Re: Unknown 440 [Re: d-150] #1534288
11/17/13 10:56 AM
11/17/13 10:56 AM
Oklahoma
lenogris Offline OP
lenogris  Offline OP
Oklahoma
ill be taking it out to a local straight road soon, track will have to wait awhile. Moving to Korea for a couple years. Plus the car needs some safety items fixed, roll bar needs to be redone, seats have to be mounted right, torsion bar cross member needs to be replaced, need a harness, and i have to find a new mount for the wheelie bar. if only i knew how to weld
Re: Unknown 440 [Re: lenogris] #1534289
11/17/13 12:08 PM
11/17/13 12:08 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Check the timing, plugs, oil change. Then put some good fuel in it & beat on it a little checking for pinging. If it runs good, the timings close & it don't ping then you have a winner. Enjoy it.
Re: Unknown 440 [Re: 80fbody] #1534290
11/17/13 01:04 PM
11/17/13 01:04 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Get it tuned up and let it rip... doesn't really matter the build, you'll find out once you pound on it. I'd set total timing at 36*, set the carb for best vacuum at idle, change the oil/filters, check the plugs and roll. Hammer it try shifting at 5800, then 6000 if it feels like it's still pulling try 6200... You can also add some timing until it pings or falls off.
Coming soon!!!!
