Truck header / ground clearance
#1534029
11/16/13 12:14 PM
11/16/13 12:14 PM
Posts: 65 Huntsville, AL
venom107
Huntsville, AL
Looking for advise from anyone running headers on a lowered big block. The headers I had purchased hung way below the frame rail. It left me with only about 3" clearance. Looking for a header that does not drop below the frame rail. In a rush, I went and ordered a set of block huggers, which will be fine for the current engine, but would be limiting on future plans.
Re: Truck header / ground clearance
[Re: BulletBob]
#1534033
11/16/13 09:19 PM
11/16/13 09:19 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Do you need big tube headers? In not then the e body shorty headers will fit really well.
Back when they were first introduced there used to be a bunch of info on here about installing them in the trucks.
And the big plus was they used the ball socket style flange to the lead pipes.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
