Who runs a solid cam on the street? #153389
11/19/08 02:56 PM
11/19/08 02:56 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
And how do you like it?
Re: Who runs a solid cam on the street? [Re: StealthWedge67] #153390
11/19/08 03:17 PM
11/19/08 03:17 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i run a solid in my 65 coronet 440 6-pak. engine runs smoother and is easier to tune. more flexiable than a hydraulic.
Re: Who runs a solid cam on the street? [Re: StealthWedge67] #153391
11/19/08 03:21 PM
11/19/08 03:21 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Love it.
Re: Who runs a solid cam on the street? [Re: goldmember] #153392
11/19/08 03:30 PM
11/19/08 03:30 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
my charger is getting a 440 w/ a mopar 528 solid and a six-pack. I was told it should run great.
Re: Who runs a solid cam on the street? [Re: Mr.Yuck] #153393
11/19/08 04:35 PM
11/19/08 04:35 PM
i do. hughes solid 565/576 lift 245/250 @ .050
runs great. the clacking makes you a little nervous but it goes away mostly once its good and warm (5 miles down the road). its harder to hear with the glasspacks tho
Re: Who runs a solid cam on the street? #153394
11/19/08 04:54 PM
11/19/08 04:54 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
.588 Comp solid in my 440 for the last 8 years.Great stick.Rocky
Chrysler Firepower
Re: Who runs a solid cam on the street? [Re: therocks] #153395
11/19/08 05:10 PM
11/19/08 05:10 PM
I love them on the street!
I've run the MP .528 in a 440 and, IMO, there is no better street/strip cam!
Use some Crane iron rockers and you'll have a nice, reliable piece that makes awesome power.
Re: Who runs a solid cam on the street? #153396
11/19/08 05:23 PM
11/19/08 05:23 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Solid in my Hemi------love it.
Re: Who runs a solid cam on the street? [Re: Michael] #153397
11/19/08 05:41 PM
11/19/08 05:41 PM
Lubbock, TX
slantvaliant Offline
Lubbock, TX
Solid lifters, forged crank, 4 1/8" stroke - Gotta love the my old Slant Six!
Re: Who runs a solid cam on the street? [Re: StealthWedge67] #153398
11/19/08 06:35 PM
11/19/08 06:35 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
They work fine. Early slant sixes, 273s & early street hemis all came from the factory with them. I ran an Isky solid in my old '66 street hemi and set valves twice a year. I could have easily gotten by with just once a year, but I was a lot younger then and didn't mind working on the cars as much then.
Re: Who runs a solid cam on the street? [Re: 5spdcuda] #153399
11/19/08 07:02 PM
11/19/08 07:02 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I built a cast crank 440 for my brother that has a small solid and big valve ported 452's.... headers and torker intake with edelbrock 750 = throttle response out the wazoo....... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: Who runs a solid cam on the street? [Re: StealthWedge67] #153400
11/19/08 07:05 PM
11/19/08 07:05 PM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
I run one in my 66 charger. My fiance has pulled the valve covers to check the lash once in the 2 years we've been driving it. Like anything else, run good oil and don't run crazy spring pressures, and always break in the cam on the outer spring if using a flat tappet. Steve
Engine by DeTar http://www.kansasbadman.com
Re: Who runs a solid cam on the street? [Re: StealthWedge67] #153401
11/19/08 08:32 PM
11/19/08 08:32 PM
New Zealand
solidcam Offline
solidcam  Offline
New Zealand
For the last 24 years.Once you go solid you'll never go back.Solid lifters are your friends.
Re: Who runs a solid cam on the street? [Re: solidcam] #153402
11/19/08 08:47 PM
11/19/08 08:47 PM
Central NC
gch Offline
gch  Offline
Central NC
Small hughes solid in my 496.Alot more responsive than the hydraulic it replaced.Setting lash is a non issue.I havent done it in 2 years though it doesent get driven daily.
Re: Who runs a solid cam on the street? [Re: gch] #153403
11/19/08 10:10 PM
11/19/08 10:10 PM
IN
ahy Offline
ahy  Offline
IN
I'm running a MM grind solid. 243@.050 and .55 lift in a 496 "B". I love it. Valve adjustment holds up well. Valvetrain upgrades (3/8 pushrods, comp pro magnum rockers) probably help keep it happy. There is a little more mechanical noise which I don't mind a bit.
Re: Who runs a solid cam on the street? [Re: ahy] #153404
11/19/08 10:17 PM
11/19/08 10:17 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Ran a 243 @ .050/ .548 Ultradyne NF solid in my old 9:1 street/strip 440. I felt like I was wasting my time every time I checked the lash since it never needed adjusted. I'm going to run the 271 @ .050/ .620 NF in my 493 Indy SR street/strip Barracuda when I finally get it together one of these years.
Re: Who runs a solid cam on the street? [Re: StealthWedge67] #153405
11/19/08 10:23 PM
11/19/08 10:23 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Lashing the valves is fun, too.
Re: Who runs a solid cam on the street? [Re: 446acuda] #153406
11/19/08 10:37 PM
11/19/08 10:37 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Worked real good on the street. It was an Ultradyne .590/.613 made for 440s in heavy cars.
Yes, mine was one of the heavy ones. 65 Plymouth
Sport Fury at 4000 lbs. Drove it darn near everyday for 4 years.
Now, the Cuda is a different story. Some cams are
just a plain b!tch on the street
Snap your neck, mega G-force launch, is all I want!
Re: Who runs a solid cam on the street? [Re: BDS871Cuda] #153407
11/20/08 12:12 AM
11/20/08 12:12 AM
Puyallup, WA
Puyallup, WA
Sounds great, my minds made up then.... I like the looks of the Hughes profiles. The 4248 looks to be a good street strip piece. Do you guys think 10* locks & retainers are a must with solid lifter valvetrain that will see 6400 rpm?
Re: Who runs a solid cam on the street? [Re: StealthWedge67] #153408
11/20/08 04:31 AM
11/20/08 04:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the MP .557 cam in my mild 440 in my 63 and I love it. I use Isky ductile iron rockers and I adjust my valves once a year. And most of the time they dont even need adjusting. I love running the solid cam in my street/strip car. Ron
