Re: Diesel Drag Racers?
[Re: Dragula]
#1533982
11/17/13 06:09 AM
11/17/13 06:09 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I realized very early that I was never going to be able to speed shift my 2002 Cummins 6 speed. I did one of the BD short shift kits to no avail. The problem is, of course, the manual truck transmissions internals that are designed to go 200,000+ miles have to be so strong and heavy to stand up to the brutal abuse of a clutch in a heavy vehicle with huge torque output, that they simply cannot change gears quickly. My 2002 QuadCab 2wd weighed nearly 7,500# empty. The only transmission that could survive would be a race prepped automatic that has the cushion of a torque converter. If you could cut the weight of the vehicle down to 2,000# you could probably have a car 4 speed (like a Chrysler) handle the job, but the big diesel engines themselves weigh well over 1,000#, so how can you build a complete light weight package around that?
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Dragula]
#1533983
11/17/13 08:25 AM
11/17/13 08:25 AM
Posts: 5,964 Greenville, PA
redraptor
Greenville, PA
Are these drag race vehicles? Was thinking more like a Lenco/Bruno or somthing....
From what I've read and saw would agree with polarapete. $5-6k upgrade and you're good to go. I swear they're shifted to OD by 100ft.
[Re: tims69belvedere]
#1533987
11/17/13 08:52 PM
11/17/13 08:52 PM
Posts: 12,397 Taxes & Virus's R-US, NY
Dragula
Some are full race, some are drivers. Plenty of options. We sometimes do a full manual. We have one guy putting the 1400 hp motor in a tube chassis fiberglass 30's willys. Insane! We are going too either make his 48 full manual or start over with a 47re and make it full manual with out fat input shaft, and the intermediate, and output shaft.
Full manual, how many gears? Which is better and why? Aren't they basically a 727? With the limited RPM of a diesel, don't you need more gears?
[Re: Dragula]
#1533989
11/18/13 07:53 PM
11/18/13 07:53 PM
redraptor
Greenville, PA
Well I have a small pro street step side that will fit a diesel...With a 360 and a heavy A500 it weighs only 3250lbs, was curious what trans would allow it to run 10s consistantly...
I thought you got rid of that truck? Yes? I would be concerned about the frame/suspension combo to handle the torque AND be consistent. I would contact CumminsExpress and ask him what he had. I seen him at Norwalk 6 years ago and he was down around that time.
[Re: Dragula]
#1533991
11/19/13 09:31 PM
11/19/13 09:31 PM
redraptor
Greenville, PA
Wouldn't a full manual 727 just work then?
I suppose if you can adapt a bell to fit I'm sure it would. It would for sure be WAY different shifting so quick compared to gas but you're already familiar with diesels.
[Re: redraptor]
#1533992
11/20/13 08:43 AM
11/20/13 08:43 AM
Dragula
I know from owning a bunch of them now that they really live in the lower RPM range...The milder the gear, the more they pull...Not sure I like the auto behind the diesel, at least not for towing, but for racing, its really the only way to spool a turbo motor as they need some load. Just curious about what the 9-10 second guys run in a race preped vehicle, not a daily driver type...Worse comes to worse a 727 with a GV unit and use it as a 4th gear.
[Re: Dragula]
#1533993
11/20/13 09:04 AM
11/20/13 09:04 AM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
The first gen trucks in 89/90 had the 3 speed 727 behind them so no need to adapt a bell housing, those cases are out there.
[Re: Dragula]
#1533994
11/20/13 07:29 PM
11/20/13 07:29 PM
Posts: 147 Kansas
cascius
Kansas
I really am not interested in anything with OD
Just curious why? There's a lot of sled pullers and drag racers that seem to abuse the 47RH/RE's, and 48RE's without many issues. If you Google the Cummins powered Lil' Red Express truck you'll see that it's running consistent mid 10's with a best of 10.38 and is using a 47RH.
[Re: cascius]
#1533995
11/20/13 10:16 PM
11/20/13 10:16 PM
Dragula
Most of my experience is with the A500's, 904's and 727's...Not with a 47RH or anything like that. My A500 was substatially upgraded and has been flawless, but it would never handle a race prepped diesel. The factory OD is a weak link and pulls a lot of HP away from the combo due to the way its still spun even when disengaged. The guys at SMR got nervous when I wanted to put my +500hp 408/W2 in front of it. I would have had to change out the front lockup pump and convertor due to the hollow input shaft to make it live at 500hp. A big diesel makes me even more worried when I watch y-tube and see how hard they launch, just curious what everyone runs.
727's have gone as fast as 7 seconds and GV units are rated to 1200hp and I like the flow in the 727 valve bodies they make these days...Knowing I would need a trans brake valve body to spool it, I would go 727 then...Can't seem to sell it, just kinda throwing some ideas around.
[Re: cascius]
#1533997
11/21/13 09:44 AM
11/21/13 09:44 AM
Dragula
I don't have a lot of experience in drag racing or with the gasser transmissions, but I've spent a few years with the diesel transmissions. I guess my question is "Why try to reinvent the wheel?". I would think you'd spend more money trying to make a 727 with a GV strong enough to hold up than you would building a 47RH. That diesel, that's making 1500+ ft. lbs of torque doesn't care that the overdrive spins all the time.
What stall convertor do you run with one of these in a race application? And does a 47R have a Trans brake full manual valve body available? All the pro cars stage using a TB and the bump box...
I am just trying to learn a little...I have a fully prepped 727 sitting here right now. Obviously I would call one of the big names and take with one of them on handling big torque, but it seems the diesel guys are in a minority and not much info is available.
[Re: Dragula]
#1533998
11/21/13 08:08 PM
11/21/13 08:08 PM
redraptor
Greenville, PA
I disagree. You can get the info but not on this site. I agree with casius, why reinvent the wheel? I know you got a ton of money invested in what you have but, you will spend as much building a trans to handle that power as it would be to build a 500 HP 408. You are thinking of dipping into a class of expensive reliability and expensive repair compared to what you had. On a positive note, it is a blast to watch!
