they call for prem gas cause....they had 9.0 to 1 comp,with #302 heads,hart shaped closed chamberd fast burn swirlport heads
with a feed back carb,and a lean burn ECU that controled the timing with no vac can on the dist,with a knock sensor,02 senser and all that crap...the ecu can get off if the dist has been moved and out of phase...seen them turned trying to set the timming...wrong,they are locked down in a range the the ecu can control it up or down, once its out of range it trys to compenste by running rich or to lean
the vac can was on the ECU control unit and done by electronice feed back
I drop a points dist with a pertronix points coversion kit in it and run an eddy intake with an eddy carb with headers
use a vac gauge to set the timming and hook a hose from the carb to the dist for vac advance
I have advanced them up to 14* and back them down till I have no pinging on whatever grade gas you run
I like it where it will ping a little on WOT on cheap gas and no ping on prem gas....thats the jagged edge but works for most teens in any thing
run what ya brung!
