Clean out a trans cooler of old fluid whats good to use
#1533411
11/14/13 10:18 AM
11/14/13 10:18 AM
Posts: 768 Maryville tn
67coronetman
Maryville tn
I have a very nice trans cooler with a fan and filter setup just curious what is safe to use to clean it out. Plus i was thinking of using type f trans fluid heard its very good any thoughts on that........ Thanks ...............
Old car are me......
Re: Clean out a trans cooler of old fluid whats good to use
[Re: 67coronetman]
#1533412
11/14/13 10:53 AM
11/14/13 10:53 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Id pump some solvent through it then follow with starting fluid.. Type F is the same stuff that B&M sells as Trick Fluid. I hear that useing type F results in a tad firmer shifts.
I am truckless..
[Re: JohnRR]
#1533414
11/14/13 12:17 PM
11/14/13 12:17 PM
Posts: 5,163 CT
GTX MATT
CT
Mark lots of guys run the Type F. You may notice it may make your trans run slightly hotter as a byproduct but nothing crazy. One of my friends likes to run half type F and half dexron so that it doesn't run too much hotter, I think hes crazy, but I'd run whatever the builder recommends.
[Re: 340SHORTY]
#1533415
11/14/13 12:51 PM
11/14/13 12:51 PM
67coronetman
Maryville tn
That is what i have heard..
[Re: JohnRR]
#1533416
11/14/13 12:52 PM
11/14/13 12:52 PM
67coronetman
Maryville tn
I will look into that thanks... Quote:
You can buy a flush that is specifically made for cleaning lines and coolers , it's in a spray can , use it and follow with compressed air .
[Re: 67coronetman]
#1533418
11/14/13 01:04 PM
11/14/13 01:04 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
I have used the flush and it is good when I have it available.
Often I don't so I disconnect the cooler lines an pump about 1/3 a can of spray Carb cleaner in one line. I attach a fuel line to the other line and put it in a gallon jug. I blow compressed air through the line and the cleaner& trans fluid spews into the jug. I repeat, swapping the direction of the flush each time until I feel good about how clean it is.
I do the flush when I take the trans out so 1. I don't have trans fluid leaking everywhere. 2. The lines have more time to dry out before I reconnect them.
The exception is that I don't flush them if the lines are going to sit open for a while. I don't like the though of rust or creepy crawly things getting in the clean lines.
[Re: RapidRobert]
#1533422
11/14/13 06:41 PM
11/14/13 06:41 PM
67coronetman
Maryville tn
Correct it is out of the car so i will take extra care..
