Re: 03 Dodge Diesel
[Re: Dragula]
#1533160
11/14/13 03:38 PM
11/14/13 03:38 PM
Posts: 309 Franklin County VA
DRTMopar
super street
super street
Franklin County VA
Yes its a common rail, you don't have the lift pump problems like you did in the VP44 trucks. At some point you will need injectors in it somewhere around 150k miles.
08 2500 6.7 6sp
79 soon to be 440-4speed Adventurer 100
79 Warlock II
79 Lil Red
Re: 03 Dodge Diesel
[Re: Dragula]
#1533162
11/14/13 09:01 PM
11/14/13 09:01 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
Hope you aren't planning on the "Champion" check to help cover the expense of the new truck??? 'Cause I plan on abusing you at the bar for most of it!
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 03 Dodge Diesel
[Re: Dragula]
#1533164
11/15/13 12:22 PM
11/15/13 12:22 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Find out if the fuel pump is in the tank or not, the pump on the filter is a weak point. Many have replaced and gone with aftermarket.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: 03 Dodge Diesel
[Re: Savoy1964]
#1533165
11/16/13 03:12 PM
11/16/13 03:12 PM
Posts: 11,881 Fallon, Nv
SeventyGTX
Fallon, Nv
I know I should probably change the pump in my 04, 305/555, but at 180k it's still working fine. In fact everything is original in it, including the batteries and it runs like new.
Re: 03 Dodge Diesel
[Re: Savoy1964]
#1533166
11/20/13 11:56 AM
11/20/13 11:56 AM
Posts: 169 Finland, Europe
Ck[FIN]
Finland, Europe
Chrysler replaced some of the lifts pumps under warranty. Not all have changed, some of them really worked.
Use good quality fuel filter and change it once a year. Should extend the life of the injectors.
Next time you look under the hood, check the water pump for leaks, serpentine belt for cracks. Also the belt tensioner sometimes needs to be replaced, dont use the cheapest rockauto stuff.
My 03 model also needed front wheel bearing/hub in 198k miles. I bought the best SKF i could find.
you could put a smarty/bullydog/edge and add tons of power to it but the TCC will fail if it is stock.
-1965 Valiant 9.03s 358cu.in R5P7-
