Re: Difference in gas mileage between a car and pick-up
[Re: stumpy]
#1533122
11/13/13 11:44 PM
11/13/13 11:44 PM
Posts: 16,813 Between Houston & Galveston TX
SattyNoCar
I put the complete drivetrain from a '77 Gran Fury cop car (440, 727, 3.23 rear) into a '76 Club Cab. Only changes when I did the swap was using (stock) electronic ignition to replace the Lean Burn the car had and I used headers. Engine ran better with those two changes, but, as Stumpy said, lack of aerodynamics killed any real increases in MPG so it stayed about the same as what I was getting in the car. HOWEVER, strangely enough, the 440 got better mileage all day, everyday, than the 360 2bbl it replaced. If I remember correctly, I never got above 12 MPG with the 360 no matter what I did to it, or how I drove and it was real easy to get it to drop into the single digits. The 440 averaged 14 MPG and even got close to 17 on a cross country jaunt. The only time the MPG dipped down to 10-11 was when I enjoyed the wail of the TQ too much.
John
[Re: 76dodgeboy]
#1533124
11/14/13 01:12 AM
11/14/13 01:12 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Depends on Era of Fullsize car. My old 5th ave got about 20mpg after lean burn delete. Just did it to my current one and have some more tuning to do.It was getting 13-14 with the crappy lean burn. My trucks get 10 or less
But in your situation the trucks dont share gear ratio and tire diameter with the car.
[Re: QuickDodge]
#1533128
11/14/13 09:09 PM
11/14/13 09:09 PM
Posts: 2,109 Byron, NY
W.I.N. Racing
Byron, NY
A little hijack here but in the same vein... I drive my 01 3500 Cummins/auto/quad cab instead of my Chry Pacifica due to better fuel costs Pacifica = $80.00 every 4 days - Full tank Dually = 130.00 every eight days - full tank same amount of miles
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
