Tire choices for 4wd Dakota
#1532788
11/12/13 10:42 PM
11/12/13 10:42 PM
Posts: 4,323 St. Louis, Mo
318 Stroker
St. Louis, Mo
Well, I pulled the trigger and bought a sweet 2002 4wd Dakota w/60k on the clock. Club cab, 4.7, all the bells and whistles, silver with matching fiberglass shell. It's going to need new tires soon. Has Goodyear Wrangler TD 265-75-16 on it now, and they are thin. I found the window sticker in the glove box, so I know it came with 265-70-16. Any suggestions on new tires? Which size to go with? Most of my driving is on roads. It's not my daily driver, but I will daily drive it in the snow and ice, and it's will see the occasional mud on the way into the fishing hole... I'm interested mostly in handling and wear, although it'll only see 5k a year. Price is also a consideration. What say you, Moparts?
Re: Tire choices for 4wd Dakota
[Re: 318 Stroker]
#1532789
11/13/13 02:22 AM
11/13/13 02:22 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Got Michelin Cross Terrains on '01 Durango R/T. Size is 275/60-17, but maybe they make 'em in your size. Great wearing, good handling, quiet, and really good on wet pavement. Don't know how they'd be in mud or snow, as I have separate rims/tires for skiing. Like yours, car only sees 6-7Kmiles/year. Tires aren't cheap, but $70 off coupon for a set of four comes out about 4x a year for a month or so. Got 'em from Costco, but Tire Rack has 'em also, IIRC
[Re: 318 Stroker]
#1532792
11/13/13 11:28 AM
11/13/13 11:28 AM
Posts: 12,089 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
You are doing the right thing here. Research. This tire thing is getting completely out of control. Price pressures and constantly changing products allow a lot of inferior tires to come to market. I see more and more tires break cords and become un-useable while still having plenty of tread. A lot of tires are not even round. Issue after issue, some up front and some later on down the road. I change a lot of tires for my friends and neighbors. Last week a neighbor brought me a new set of Kumhos that he wanted put on his Dakota. They were the same size as the Uniroyals that he was replacing, but the tread surface was 1 1/2" narrower. He was unhappy. Last February, I put new set of BFGs on a buddie's TrailBlazer. We changed them off a couple of weeks ago after only 31,000 miles. They were worn out. He uses the 'Blazer for his sales job and usually gets 50,000 to 60,000 miles out of a set of tires. Not this time. Do your homework on tires. It is a jungle out there! And don't get me started about valves stems. I'll just say that many people are much better off keeping the old ones rather than installing new ones. Have you thought about calling the local salvage yards to find a good used set? Often $125-$200 buys a nice set of tires. Of course you have to have someone that can mount and balance them. Just a thought.
Master, again and still
[Re: DaveRS23]
#1532793
11/13/13 11:54 AM
11/13/13 11:54 AM
318 Stroker
St. Louis, Mo
That's a good idea. I have a long time friend that owns a salvage yard, and another friend with a tire mounting machine. It would sure save me a lot of money over a new set.
[Re: dogdays]
#1532796
11/13/13 02:00 PM
11/13/13 02:00 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#1532797
11/13/13 11:38 PM
11/13/13 11:38 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
From my experience, I can you what tires NOT to buy...
Goodyear Wrangler RT/S. Worst Goodyear ever!
Switched to Generals on my 93 Dakota. Still have them on my 02 Durango (2nd set, first set OEM deteriorated badly), it's only a matter of time and $$ before they go.
The thing I hate most about them, is they literally throw water up and over into the windshield! People say that's nuts, but to me, it's true. Tires are supposed to channel water away!
Common sense is a flower that does not grow in everybody's garden
[Re: Ron_M]
#1532798
11/15/13 01:11 AM
11/15/13 01:11 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Go with stock size if you are unsure of what you want 265 70. Michelins often get the vote as best tire but they have one big drawback. They last SO long they are often hard and cracked before they are worn. Especially in a car not driven alot, everyday. If you want some bite in the rain and are willing to sacrifice a bit of long term wear. Get a lower treadwear rating. A 400 will have alot more bit than a 700, especially after a few years. After reading what you plan on doing with your truck. I recommend either Nokian Rotiva's or Bridgestone A/T Revo2.
[Re: Magnum]
#1532799
11/15/13 10:15 AM
11/15/13 10:15 AM
Posts: 1,504 Bradenton, Fl 34203
Kilroy was here
Bradenton, Fl 34203
I got 78,000+ miles out of these GoodYears. I'm a very easy driver. So I put the exact same tire on.
265-70R-16
It's a 2008 Raider, a rebadged Dodge Dakota.
[Re: bee71mopar]
#1532801
11/15/13 05:29 PM
11/15/13 05:29 PM
318 Stroker
St. Louis, Mo
I have these R/T rims For sale ($1000.00) if you want to go with a bigger rim and tire...These have 1000 miles on them but shipping might be a little steep...
5 rims and 4 tires
Probably a little steep for me after I factor in the shipping, but thank you. Just out of curiosity, what size are the tires and wheels? I know from looking at my window sticker that my wheels are 16" x 8".
