Another poly question #1532477
11/11/13 11:36 PM
11/11/13 11:36 PM
Tn
tbland09 Offline OP
tbland09  Offline OP
Tn
I have posted a few questions on this forum and you guys have been super helpful so here is another.. 66 fury 3 318 poly I am wanting electronic ignition I have heard other distributors will work on the poly. Is this true and if so what are they exactly?
Re: Another poly question [Re: tbland09] #1532478
11/11/13 11:48 PM
11/11/13 11:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Any later model LA distributor will drop right in, Think 73- 79 ??? The earlier single pickup are preferred. The other option is a points conversion kit, IE: petronix, Mallory etc.
Re: Another poly question [Re: TJP] #1532479
11/11/13 11:57 PM
11/11/13 11:57 PM
Tn
tbland09 Offline OP
tbland09  Offline OP
Tn
http://www.summitracing.com/parts/pnx-1381a/overview/make/plymouth
Is this what you are talking about? What would the better choice be ?
Re: Another poly question [Re: tbland09] #1532480
11/12/13 12:05 AM
11/12/13 12:05 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
yes, the draw back is if the aftermarket unit IE: in this case takes a dump, you either have to convert it back to points on the side of the road, or call a hook. They are typically very reliable, only seen 3 or 4 failures over 30 years.
The factory conversions on the other hand require a bit more work to install correctly but parts are available anywhere (usually). We are talking 30 old year technology, But they ( the MFR's) used the same stuff in millions ? of vehicles so the parts are typically available for the factory conversions.
if the after market stuff takes a dump You're DONE!!! hope this helps
Re: Another poly question [Re: tbland09] #1532481
11/12/13 12:10 AM
11/12/13 12:10 AM
Andrewh Offline
Andrewh  Offline
just drop pertronix under the cap and it will work fine.
Re: Another poly question [Re: TJP] #1532482
11/12/13 12:12 AM
11/12/13 12:12 AM
Tn
tbland09 Offline OP
tbland09  Offline OP
Tn
Awesome thanks a lot!!
