Re: T/A AAR 4 speed?
[Re: ragtop]
#1532306
11/11/13 09:05 PM
11/11/13 09:05 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I know that they came with close ratio gears, but did they have the Interlock style side cover instead of the Ball & Detent style? Also, did they come with the bolt on style shifter handle instead of the bayonet style? Thanks.
1970 NP833 had ball and detent side covers, 1971 was the first year for the GM style side covers I believe. I had a J code 1970 Challenger T/A 4 speed CA car, I can't remember now if the shift handle bolted on or slid in I'm almost Positive that all the 1970 and 71 E body short pistol grip shifters I've seen had the bolt on handles, maybe not What say you Scott Smith Harms
[Re: 340swing]
#1532309
11/11/13 09:59 PM
11/11/13 09:59 PM
Posts: 1,567 Ky
jt4406
Ky
Not sure here but I believe all 70 OEM shifters are slip in handle, not sure after that. Actually I was under the impression all OEM shifters were slip in and a bolt on was aftermarket... jess
Yeah, it's hopped up to over 160...
