Where did you hook up your Electric Fan?
#153165
11/19/08 01:34 AM
11/19/08 01:34 AM
Posts: 227 Scottsdale, AZ
Cudalord
Scottsdale, AZ
I recently hooked up an electric fan on my 70 Cuda, and I was wondering where to hook the "ignition on" wire. I tried hooking it up to the bulkhead above the Reverse Light hookup, but tonight I ran it and the fan never came on. I hooked up the power source direct to the battery, and the fan turned on right away. Obviously I need to find a more constant, non fused hookup or wire it directly to the battery.
I'm running a 210 dual fan with 35 Bosch Relay and adjustable thermo if that matters. I have the "high" side hooked up direct to the battery with a fuse.
Any suggestions?
Re: Where did you hook up your Electric Fan?
[Re: 451Mopar]
#153167
11/19/08 10:46 AM
11/19/08 10:46 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
If you have an adjustable set up. You can also connect the ignition on wire to a constant on source.
Then the fans will continue to run when the engine is hot and the key is off. It will often cycle after you shut it down.
Make sure your off temperature is higher than your thermostat temp. Run the power wire directly to the battery. Your original wiring harness was never meant to take the load of electric fans.
[Re: Magnum]
#153168
11/19/08 12:14 PM
11/19/08 12:14 PM
Andrewh
While this works, I discovered a down side to this. If you make a lot of short trips, you need a jump when you are done to get home. I mainly cruise around town. Short hops around the coroner to get little odds and ends, and when I had my fan hooked up like that, I found that after 3 or 4 stops, I no longer had enough juice to crank over the car.
[Re: Andrewh]
#153169
11/19/08 01:01 PM
11/19/08 01:01 PM
and i dont like connecting high current devices to the +12v ignition source under the hood. high current fans will drop that 12v to the ignition . grab your 12v somehwere else- another circuit.
[Re: 440dodge440]
#153171
11/19/08 01:57 PM
11/19/08 01:57 PM
sorry, i misread the above post. still, I'd grab my relay control from a different place and not the ign at the ballast
