Re: another dumb hemi ?
[Re: headhunter]
#1531630
11/11/13 12:43 AM
11/11/13 12:43 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Who made the headers? Do they have slip-on collectors? I had Hedman Husler 2-1/4" headers in my Duster, and the collectors did not hit the trans.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: headhunter]
#1531633
11/11/13 10:35 AM
11/11/13 10:35 AM
Posts: 12,174 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Mine are Hedmans. The flanges pointed the exhaust right into the tranny cross member. So I had the collectors redone and made them longer and into an S shape to get them into the exhaust reliefs in the cross member. It is close to the tranny, but not bad. It's actually tighter on the driver's side on mine.
I had heard that the fit wasn't that good with these headers, so I ordered them without coating expecting to mod them up.
Then they went to CCP Coatings. CCP did the best coating job I have ever had on a set of headers. They are all I will use in the future.
Master, again and still
[Re: headhunter]
#1531639
11/12/13 10:12 PM
11/12/13 10:12 PM
Posts: 2,601 ky
headhunter
ky
[Re: headhunter]
#1531640
11/12/13 10:14 PM
11/12/13 10:14 PM
Posts: 2,601 ky
headhunter
ky
[Re: headhunter]
#1531641
11/12/13 10:18 PM
11/12/13 10:18 PM
Posts: 2,601 ky
headhunter
ky
[Re: OUTLAWSSAA]
#1531644
11/13/13 12:02 PM
11/13/13 12:02 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Don't get frustrated. Every spot that you referenced had to be clearanced on my car. Its normal when putting a hemi in an A-body.
If fabrication isn't your thing you may be better off with a SB.
[Re: headhunter]
#1531645
11/13/13 12:57 PM
11/13/13 12:57 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
Those hoooker headers will hit stuff. no way around it. The only thing you could do is have a header builder rework a couple tubes, or put a few dents in it.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: HemiDart68]
#1531646
11/13/13 01:05 PM
11/13/13 01:05 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
well an old school Hemi is certainly a combo it never had. But with the motor plate it could be moved slightly to allow for clearance. Unless you are using the midplate as well. Then you will need to do some fab work to move it. Same kind of stuff was done to convert from a BB to the 99
[Re: headhunter]
#1531647
11/13/13 03:58 PM
11/13/13 03:58 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I ended up having 3 tubes and both collectors reworked and still had to cut 2 notches in the frame.
Fitting the old Keith Black block into my Dart was so difficult, I had to block the body up as high as I could get it and then raise the engine up into place with a cherry picker and the tranny with a jack until I found a problem point. Then, remove the engine and tranny so I could address the issue.
31 times! But it fits good and I am happy that it is over.
[Re: rowin4]
#1531648
11/13/13 10:27 PM
11/13/13 10:27 PM
Posts: 2,601 ky
headhunter
ky
thanks now I need to know how far the valve cover on the passengers side should be from the shock tower ? mine is touching it and the rear header tube on the driver side is touching the frame
c
Your problem is you have elephant a ear front mount, you probably could move the engine a inch by just loosening up the water pump bolts and rotating the engine. Get a motor plate from AndyF.
what type of motor plate does he sell?
