1998 stratus p300 random misfire #1531354
11/10/13 07:33 PM
11/10/13 07:33 PM
Nashport, OH
chargers777 Offline OP
Nashport, OH
new plugs,wires,coil pack,camshaft sensor,crankshaft sensor,fuel pump.What else could it be?Happens after driving a couple days and about 75 miles.
Re: 1998 stratus p300 random misfire [Re: chargers777] #1531355
11/10/13 07:36 PM
11/10/13 07:36 PM
SE PA
Yellow Fever Offline
SE PA
EGR valve hanging open maybe?
http://www.random-misfire.com/
Re: 1998 stratus p300 random misfire [Re: Yellow Fever] #1531356
11/11/13 09:27 AM
11/11/13 09:27 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Did you just read codes or actually have it scanned to see live data?Sounds like it had a bunch of parts tossed at it.Just seeing codes isnt the same as live data stream.It could be EGR but they will usually set a code.Ive also seen where the heated O2 sensors can cause a misfire and not set a code.Thats why live data such as fuel trim,injector pulse etc is important.Rocky
Chrysler Firepower
Re: 1998 stratus p300 random misfire [Re: therocks] #1531357
11/11/13 09:24 PM
11/11/13 09:24 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
i have seen low compression do the same
