2001 Jeep GC 4.0 4x4 auto trans replacement??
#1531071
11/09/13 11:24 PM
11/09/13 11:24 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Any pointers? GC has Quadratrac II, AWD system. Plan is to pull it on the ground from the bottom (front of truck up), leaving the 4.0 in place. Drop drive shafts and remove the cross member and transfer case?
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
Re: 2001 Jeep GC 4.0 4x4 auto trans replacement??
[Re: Geezer]
#1531074
11/16/13 08:34 PM
11/16/13 08:34 PM
GO_Fish
Maryland
You got me digging further... 42 is front wheel drive trans. GC has (I think?)a 45RFE (or later 545RFE). Made good progress getting it out today. Parts store lists spin on filter and valve body filters... Have not found the spin on filter yet, will need to trace down the cooling lines.
Scott B.
[Re: 71yelladustr]
#1531076
11/17/13 03:41 AM
11/17/13 03:41 AM
GO_Fish
Maryland
Okay, thanks for the clarification! I've got some parts to return to the NAPA guys & get them to look up the right stuff... Removal is going easier than expected. No significant rust to deal with. A few odd braces/rods above and below the trans, I suppose to counter driveline torque.
Scott B.
[Re: GO_Fish]
#1531077
11/23/13 03:16 PM
11/23/13 03:16 PM
GO_Fish
Maryland
Hopefully one of the torque converter bolts is offset so they can only bolt to the flex plate one way? If they are offset, it appears minimal. I guess to reduce vibration?
Scott B.
[Re: 71yelladustr]
#1531079
11/23/13 08:12 PM
11/23/13 08:12 PM
GO_Fish
Maryland
Sweet! That's a relief. Just bolt it up and go sounds like.
Scott B.
[Re: GO_Fish]
#1531081
12/08/13 12:39 AM
12/08/13 12:39 AM
GO_Fish
Maryland
The shifter cable adjustment was underneath the console inside the cab. Starts fine now, and Park is Park. Now I have a bad vibration at 25-35 mph that I need to track down. I'll check the obvious, U-joints. Something is shaking this thing BAD.
Scott B.
[Re: GO_Fish]
#1531082
12/15/13 06:28 PM
12/15/13 06:28 PM
GO_Fish
Maryland
Got out today between storm systems and crawled under the Jeep. Found that my GF's son didn't center the rear U joint in the yoke. They tried to make the design goof proof, but he still missed it. Loosened the straps and centered the joint, now the vibration is gone. Next sunny day I want to go over everything one last time before it goes back on the road.
Scott B.
