Page 1 of 3 1 2 3
Cummings mileage #1530648
11/09/13 06:08 PM
11/09/13 06:08 PM
North Eastern New York State
montessa Offline OP
montessa  Offline OP
Thinking about trading my 2011 Hemi 2500 for a Cummings. I love my truck but was thinking about swapping it while it still worth something. I average about 12 around town and 8 pulling 9000lbs. My current ride has 4.10's and does the job around my part of the country just fine but just want to hear numbers from the real world guys on the Cummings. I am also considering the 6.4 Hemi. I figure the mileage should be on a par or a little worse the 5.7 but with more grunt. Comments, Thanks Jim T.
Re: Cummings mileage [Re: montessa] #1530649
11/09/13 06:33 PM
11/09/13 06:33 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Mine is a '06 3500, Cummins, 4 X 4, auto. Not towing, I get almost 19 mpg as long as I keep the speed around 70, any higher and the mpg drops to approx 17. With a 26' enclosed tag trailer loaded to the max (10,500 lbs), I get about 12-13 mpg, unless I try to run over 70, then it drops to about 10.5-11. There is no lack of grunt here though.
Brian
Re: Cummings mileage [Re: montessa] #1530650
11/09/13 06:35 PM
11/09/13 06:35 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
CUMMINS
When they went to 24v the mpg dropped. My 12v doesn't hesitate to see 24mpg highway with a non lock up converter. My brother's 97 12v will get 28. Both trucks have fuel and turbo mods.
Edit we both get around 20 towing kinda heavy and not pussy footing them, they belch smoke from a stop, spool up and GO
Re: Cummings mileage [Re: montessa] #1530651
11/09/13 06:37 PM
11/09/13 06:37 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My 2006 diesel was getting 12.5-13 mpg towing my 24 foot enclosed trailer, quad, race supplies, and tools. My exhaust broke in front of the stock factory muffler and my mileage jumped up to 14.5-15mpg towing in hilly Pa. I bought an after marker air cleaner (didn't put it on yet) and will be upgrading the exhaust next Spring. It still has the stock computer setting and has more than enough power.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cummings mileage [Re: pittsburghracer] #1530652
11/09/13 06:46 PM
11/09/13 06:46 PM
montessa Offline OP
montessa  Offline OP
Did the mileage get even worse when they switched to the urea system?
Re: Cummings mileage [Re: montessa] #1530653
11/09/13 07:08 PM
11/09/13 07:08 PM
MI
68shifter Offline
68shifter  Offline
MI
No. I have a 2013. 6.7L with 3.42's. Empty I get 22 area at 70-75, if I drive 55 I'll get 25. When pulling my 28ft enclosed with cabinets/insulation/car etc.., around 12k I averaged 13.5 from Mi to Pittsburgh. It'll do a bit better on flatter tows.
The exhaust brake is phenomenal on the new trucks. Also, you use about 1 gal of DEF per 1000 miles at about $6 a gallon. Just an average though.
Good luck.
Also good first hand knowledge here too on 2013+
http://www.cumminsforum.com/forum/2013-general-discussion/
Re: Cummings mileage [Re: montessa] #1530654
11/09/13 07:30 PM
11/09/13 07:30 PM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
My 2001 5.9 24v Cummins with a Hypertech Stage 3 map pulls 23-24 hiway at 65-70 mph. Pulled my brother in law's 28.5 foot Alpenlite 5th wheel from Bakersfield to Sacramento, averaged 15 mpg @ 60mph, had to use cruise because it kept creeping up to 65-70 if I wasn't paying attention.
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: Cummings mileage [Re: 1KoolBee] #1530655
11/09/13 07:47 PM
11/09/13 07:47 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
2009 6.7 litre with 6 speed auto 12 towing car trailer , will do 22 on the highway at 65. Had a 5.9 12 valve with a manual was a little better but not all that much. I have had 7 diesel pickups going all the way back to the first cummins in a pickup ( that was a gutless wonder) and none of them ever managed to get the mileage I heard claimed by others. On the flip side I did own a hemi ram and that was a pretty thirsty vehicle especially towing made the diesel seem like an economy car.
76 Duster work in progress
Re: Cummings mileage [Re: montessa] #1530656
11/09/13 08:00 PM
11/09/13 08:00 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
I have an 06. Had an 01 and 02. The newer trucks get worse mileage than the earlier trucks. These high mpg guys are either going by the lie o meter or live in areas with no hills.
My truck will get 14 to 15 around here. On the high way about 20 mpg. Towing 12,000 lbs about 11-12 mpg.
My son has the 02. The truck gets 18 around our area but it is also a stick. On the highway he gets about 22 mpg.
Don't expect a new truck to even get these numbers. Expect 12 around town maybe 19 highway empty and 11 towing. If you get more great but dont expect it.
Re: Cummings mileage [Re: DodgeCharger] #1530657
11/09/13 09:14 PM
11/09/13 09:14 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Previous owner (somewhere in its life) abused 96, 3500, 46re, ext.cab, long bed, 4x4, 280k, stock exhaust with catalytic converter(may be nothing left in there, don't know), & no motor mod's. Tires are taller than stock though.
My 1st pull was with a 28' inclosed with car. Not knowing what speed would give the best mpg, doing ~65-70 I got ~10 mpg. I was hoping for 12. I could feel the wind pushing hard on the flat nose of the trailer. Maybe I had a head wind too, don't remember.
This yr had a chance to check it empty, on a trip 20.7, that surprised me a little.
To town & around & back, don't know.
Re: Cummings mileage [Re: thehemikid] #1530658
11/09/13 09:27 PM
11/09/13 09:27 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
2005 Dually 18 highway empty and 11 towing a loaded gooseneck.
With some tricks it gets 23 highway and 14 towing.
I have been around some of the high mileage claiming people too. They seem to always have excuses when we are traveling together.
I am perfectly happy with a 7,600 lb truck that will run like stink getting 23 and pull like crazy and get 14.
Leon
Re: Cummings mileage [Re: thehemikid] #1530659
11/09/13 09:29 PM
11/09/13 09:29 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Now do some fuel mods and get more mpg. 12v > 24v
Re: Cummings mileage [Re: thehemikid] #1530660
11/09/13 09:29 PM
11/09/13 09:29 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I would never own a gas rig again for towing. Mine gets 15-17 around town and highway, 8.5-11 towing a 40' aluminum goose neck, chipped, exhaust, intake, stock tires and wheels. I tow around 75-80mpg but have tried to haul slower, doesn't much matter. It's a 2004.5, 3500 dually, and I laugh at people who quote 20+MPG, it's BS in my opinion. Every time I get in somebody's rig that gets that kinda mileage, it doesn't. Great power though and long living if you take care of them....
Re: Cummings mileage [Re: camastomcat] #1530661
11/09/13 09:51 PM
11/09/13 09:51 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
2007 5.9 routinely get 22mpg empty on the thruway 14-16 around town and 12 towing a box at 70-75mph. Love it and will not go back to gas..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Cummings mileage [Re: Eric] #1530662
11/09/13 10:32 PM
11/09/13 10:32 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
My Cummins was a 2002 with HO and 6 speed manual. I averaged 17 in mixed mostly city driving. Pulling an 8,000# trailer on the highway it would do 13. I had the gauges (EGT and boost) and 4" stainless exhaust. PO had installed different injectors, a South Bend clutch and I had a timing kit that I never felt the need to install. If you can afford the maintenance, go for it, every man needs to own a locomotive once in his life I loved it. Would I own another? Only if I needed the power every day and would use it like they should be used
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Cummings mileage [Re: Polarapete] #1530663
11/09/13 10:54 PM
11/09/13 10:54 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
personally i've seen too many fish stories about cummins (or others for that matter) mileage and i own a 97 stick. iirc it will do 17ish unloaded and probably 13-14ish pulling about 10k of 40' goose. it's a great engine but some of the claims i've seen...well you get the idea, there's a lot of john holmes mileage stories afaic
Re: Cummings mileage [Re: jamesc] #1530664
11/09/13 11:01 PM
11/09/13 11:01 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
These threads are usually full of BS but this one looks pretty honest so far. My 05 automatic 4WD gets above 20MPG empty and recently did 12MPG pulling a 24 ft enclosed down to Seattle and back. The mileage seemed the same with the trailer loaded or empty, the enclosed buck a lot of wind. I do better pulling an open trailer but can't remember how well now, I think something like 15-17MPG with a loaded open trailer.
Sheldon
Re: Cummings mileage [Re: RUNCHARGER] #1530665
11/09/13 11:12 PM
11/09/13 11:12 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
2011 Ram 3500 4x4 Cab and Chassis, automatic, CM SK Bed. 8912lb empty (scaled) 16.5mpg (70mph). Was able to achieve 23mpg before bed was installed (60mph)
When hauling Jimmy's Dart home from Orlando, I averaged roughly 13.5mpg with the loaded enclosed trailer (65-70 mph varying between states)
Re: Cummings mileage [Re: jamesc] #1530666
11/09/13 11:52 PM
11/09/13 11:52 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
97 2500 4x4. Unloaded about 20. Loaded down with cabover, enclosed trailer with b body, tools etc. and enduro hangin off the front hitch about 11-12.
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Cummings mileage [Re: montessa] #1530667
11/10/13 12:32 AM
11/10/13 12:32 AM
Mesa , Az
Jambbii Offline
Jambbii  Offline
Mesa , Az
I am not sure if I believe some of these mileage claims but once you go Cummins you will not regret it. My 06 gets and average of 16.5 making a tick over 500hp at the rears and will still get about 12-13 towing 10k.
Josh
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Page 1 of 3 1 2 3
